Results 1 to 8 of 8
Thread: indicator lights on dash
    vz ssz silver ute
    Feb 2010
    perth WA
    Default indicator lights on dash
    ok ill tell you a story and yes it will be hard to understand cause i dont get it either my indicator lights work when i push my hazard button in and only work some times when i indicate any reason for this also at night only a bit of my dash cluster i think its called works so its lit up a little on the revs and a little on the speedo almost hard to see if i go faster than a hundred cheers any in put would be great
    My vz ssz ute
    THOSE WHO CRITICIZE OUR GENERATION FORGET WHO RAISED IT
    vz ssz silver ute
    Feb 2010
    perth WA
    sorry ment to say my indicators on my dash cluster not my outside indicators sorry my mistake
    My vz ssz ute
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Quote Originally Posted by BRAWT_4TH View Post
    Add some full stops to that and it should be a bit easier to understand!
    vz ssz silver ute
    Feb 2010
    perth WA
    any one else wish to not help
    My vz ssz ute
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You'd probably be best to remove the dash console and reinstal - this way you can make sure all the plugs and connectors are fully pushed in and making good connection. There is a how-to in that section. Use the one that talks about fixing a speedo as that procedure requires dash removal.
    I know there can also be a problem with the hazard lights switch - if it plays up you can lose indicators etc....maybe that would be first thing to do as it's a lot easier than pulling the dash.
    Good Luck.
    vz ssz silver ute
    Feb 2010
    perth WA
    yeah but liek i said when i push the hazard button both lights flash on the dash cluster but when i indicate right or left it doesnt show up could it be the actual indicator arm on the right hand side ?
    My vz ssz ute
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    OK - now I'm with you, you've probably got bulbs blown in your dash display which will cause only part of the display to light up, however if the turn indicator lights on the dash only sometimes light up then that means you have a bad contact/connection as per my first post. The hazard switch can cause strange problems!!! I don't think it's the indicator arm. I also note you have a Statesman which may have a more exotic dash display than the poor man's Exec that I've got, maybe someone else with a Stato can advise better. Good Luck.
    Rusty's Avatar
    Mar 2010
    Queensland
    I was helping you by suggesting you make your thread easier to read! If you did that, more people would help you!!
    Not having a go at ya
  1. vn Calais rear lights, rear indicator, reverse lights and fuel gauge stop working
    By rustyguy085 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2009, 08:25 PM
  2. VY indicator lights on VX
    By Dan_VX_Spac in forum General Discussion
    Last Post: 10-12-2008, 07:59 PM
  3. vs lights/indicator
    By oldmate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2007, 05:53 PM
  4. Dash Lights/Shift Indicator Fuse Blowing?
    By svs500 in forum Electrical Wiring / Questions
    Last Post: 29-11-2005, 03:38 PM
