Results 1 to 3 of 3
Thread: Vr Help
    VR Executive V6
    Jun 2010
    Carrum Downs, Victoria
    Default Vr Help
    Hey guys
    lately ive noticed that my vr has been leaking, puddle underneath car, ive checked all the fluids (oil, radiator, cooling, brakes, transmission etc) they remained full and concluded it isnt any of them, a friend suggested that the leaks may be the heater/air con system, which makes sense since im using the demister alot since its winter, just wondering if anyone else has had this problem and if it is a serious issue?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The aircon will usually condense water as it cools the air and dumps it approximately under the middle of the car...usually very noticeable on hot humid days...I'm a Q'lander so not sure about cold weather and demister but I suppose the aircon is still on when demisting and the mist has to go somewhere. What I'd do is park over some clean paper and check the colour of whatever is leaking - if it's clean water then it is the aircon and normal.
    Good Luck.
    VR Executive V6
    Jun 2010
    ye its very cold down here in Melbourne, very wet, ill do the paper thing over the weekend and see what happens.
    if the water isnt clear, is a damaged air con/heater system bad or just a big inconvenience?
