Results 1 to 4 of 4
Thread: vs head
    VS Commodore s2 3.8
    Jul 2010
    tamworth
    Default vs head
    can some one please tell me if a VN/VP head will fit on VS plz?and is there anything i have to do to it ? and what are the first signs of a cracked head or blown gasket? because i put water in my radiator today and in a space of approximatley 1 hrs driving (not constantly)it went through about .5 of a ltr if water and the temp gauge was at 3quarter temp..i also think it could be a thermostat but my main concern is the head.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    look at the inlet manifold gaskets first, ohh and no vs heads will not fit.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I wouldnt fret too much, head are going a dime a dozen these days. You can pick up a good second hand set and swap them over. But first find out if its really your problem yet. Like above, could just be your inlet maifold gasket leaking(very common on these engines) and is a relativly easy fix to pull off the inlet manifold off and replace the gasket.
    Reaper
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    If you are going to take off your inlet manifold... PLEASE remember these few things...
    1. BEFORE you disconnect your fuel lines - DEPRESSURISE them, nothing worse then having fuel go into your eyes
    2. Drop your oil and change your oil filter...
    Not important, but i always do it if it looks old
    3. Change your thermostat
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
  1. Head unit running off head lights?
    By billyjim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2010, 04:44 PM
  2. head lights cut out head unit.
    By Silver_VS_II in forum Electrical Wiring / Questions
    Last Post: 03-05-2010, 11:39 AM
  3. Ecotec head gasket replacement and head linish
    By VOSBMX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2010, 10:08 AM
  4. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  5. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
