OK so my vr has a couple of issues with starting ive almost cut it back to minimal expcept tonight..it cut out and sounded liek it had nothign while whinning over then itkicked so im ordering a new fuel pump...some new injectors and was thinking of a multi-point earth kit or even a second maybe 0 gauge eart.. what do you guys recommand
The earthing system in the car is adequate as long as it is in good order, if your doing this for the sole purpose of fixing a problem i would simply say you throwing money away. There would be somthing very simple wrong with what you have that possibly needs minimal work to rectify. If you had a real purpose and need for a good eathing system then you would do it, but it seems you simply have a problem somwhere. Your post dosnt read to well and im not sure what your saying as far as your problems??
so never been good with word..basically my car jsut whines then itl kick lst night it stalled and wihile trying to start it it sounded as if the battery was dead..but its not,,its a 4wd battery...i fixed up my first earth it stopped a lil but my lead have white spots so im changing them today
turn your headlights on for 2 min on high beam, engine off.
if after this time the car starts your battery is good. its called load testing the battery. they may have 12v but its the amps that is required. ive seen good battery die overnight with nothing hooked up.
Originally Posted by Adam Savage (mythbusters)
