hi all my car is hiting bump stops every time i go over a bump how can i stop this without raising my car
hey mate, just cut em down. what is it lower on?
when i dumpd my ute on sl kings, i had to cut them to 60mm in size. was easy enough job. just pull them off and cut them down with a hacksaw.
gd luck budy
hmm but antonio you have a ute. The ute bumpstops are different to a sedan.
my car sits really low if i can get pics up i will the quarter is just under the top of the rim you cant see any tyre im running 17s at the moment
wow that is low. really all you can do is cut away some bumstop or remove it completly but i wouldnt recoment either of those
there isnt much left of the bump stops as they are there all worn oway and just found out my exhast rubbers are screwed so its just hangn
