Results 1 to 4 of 4
Thread: Fuel sender
    VR_meanz is offline VR_meanz
    VR 3.8 (5 speed)
    Dec 2008
    Default Fuel sender
    Is there any way to check the fuel sender without taking everything apart. Can you maybe earth out one of the wires to see if the gauge is working at all? If not what should i do? Thankyou
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If you have a Level 3 cluster you can check the volts comming from the sender within diag mode (2). A multi meter would probably do the same job if you have L2 cluster. 4.4 = full and 10.0 = empty or something like those numbers from memory.
    and 3 Dangerous non ABS VN's
    VP Exec
    Jun 2005
    Earthing the wires isn't a good idea because it can damage the gauge but you can chack the gauge and measure the resistance of the sender.
    Check at the white plug on the front of the sender. Unpug it - it will have three terminal positions but only the outer two are used. Put a ~270 ohm resister across the terminals on the harness end, ignition "on", the gauge should read empty; 100 ohm, half; ~40 ohm full.
    The sender in the tank should have the same resistances across the terminals corresponding to the level in the tank - guess, dip with a wire or smack the tank.
    There should be 10V on the tan wire at the harness terminal.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    just tap the dash, most of the time the dash plays up.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
  1. fuel sender
    By MRVX6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2011, 05:02 PM
  2. Fuel gauge or Fuel sender?
    By Defected in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 03:19 PM
  3. Fuel sender removal on VS.
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2009, 05:56 PM
  4. VX LPG Fuel Sender
    By deserthead in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2009, 09:59 PM
  5. wtb fuel sender and assembley
    By ralph_vt in forum Swap / Wanted to Buy / Trade
    Last Post: 29-09-2007, 07:08 PM
