Results 1 to 14 of 14
Thread: Will VZ struts fit my VR??
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Default Will VZ struts fit my VR??
    Anyone know if VZ struts will fit my VR? To me they look the same.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I beleive they will, but im not 100% on that, so not much help there. But in the back of my memory, i seem to rember a bloke at work put them in his vr ute.
    Reaper
    Chirpstr's Avatar
    Sep 2007
    Cool thanks. Hopefully I can still use my standard sway bar/link rod as well.
    Chirpstr's Avatar
    Sep 2007
    I thought I'd throw a pic in as to what I'm looking at getting. Apparently they are from a VZ senator?
    Are they true coil overs?
    Attached Thumbnails Attached Thumbnails Will VZ struts fit my VR??-untitled.jpg
    VY Berlina V6 / R31 Skyline
    Dec 2008
    The link pins will not match up with your sway bar mate.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    Chirpstr's Avatar
    Sep 2007
    Quote Originally Posted by sweefu View Post
    That's why I said "hopefully I can still use my standard sway bar/link rods as well." ^^^^^
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by Chirpstr View Post
    Easiest way to be sure would be to go and get a few parts catalogs from the websites of shock and strut manufacturers and see if the part numbers are the same. They look pretty worn though, looks like you would have to bolt in the swaybar links from your VR or get a set of better after market ones.
    They kinda look like coilovers, but not as I know them - all the coilovers that I've seen look like this (coilover on left, regular strut on right) -
    Dec 2009
    Those struts are from a VX Series 2 to VY. The VZ has a ball joint end on both ends of the sway bar link pins.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Smile
    Quote Originally Posted by wortus View Post
    I believe that statement is wrong.
    All the HSV Z range I have seen (including my own Senator) have been fitted with VX2-VY style strut.
    Maybe HSV did it to save cost of engineering a strut for one single model or maybe the VY strut was deemed good enough for the Z until the VE came out.
    To the OP (chirpstr):
    The struts you pictured will fit your VR using your VR link pins with no problems .
    The same style strut was used from VR-VY .
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    They are definitely not HSV std they look like coil overs using a VR-VZ irs style rear spring .
    Chirpstr's Avatar
    Sep 2007
    Quote Originally Posted by Surfwagon View Post
    Yeah that's what it looks like hey? Irs rear springs.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Yep they sure look like IRS rears, wonder who actually built them .
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    They are not an IRS rear spring out of a Commodore as the coils are different thicknesses and diameter top and bottom on the Commodore spring. Somebody went to a lot of effort to modify standard struts to take those springs. They look like they are adjustable, but I don't see any threads cut into the strut.
    Visit my Facebook page
    Chirpstr's Avatar
    Sep 2007
    Thanks NAAF. He's some a couple pics showing threads as well.
    Will VZ struts fit my VR??-untitled3.jpgWill VZ struts fit my VR??-untitled1.jpg
  1. VS struts in VL
    By Abrowne70 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-02-2011, 10:59 PM
  2. struts?
    By mynameisearl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2010, 07:23 AM
  3. 97 and 00 struts the same??
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2008, 03:12 PM
  4. Gas struts
    By fatboy2869 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-01-2006, 12:41 PM
  5. Vr /vs Struts
    By RVN 355 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-11-2005, 11:54 AM
