My Statesman started to feel like it was losing power on the way to work (Geelong to Melbourne) then got onto highway and dropped into overdrive and started to shudder real bad then 2klm's down the road it stopped dead will turn over but no fire on gas or petrol, any ideas?
I'm getting a tow soon.
Just did code check and it came up with -
Code 12 - System Pass (OK)
Code 76 - Air/Fuel ratio variation between left and right banks.
But then the low fuel light, temp light and speed alert light started to flash as well but not sure if that's because the battery is low?
Jumped and still just turns over with no fire fuel pump still works i heard it pumping fuel when i turned on ignition.
air fuel variationi think comes from the oxygen sensors(i think you have 2, one for each bank) and that could be do do with the gas if its a mixer setup and possibly not an issue. You'll have to get a tow atm though i would say. Dosnt sound like somthing your gonna fix on the hwy.
I should have mentioned it's gas injection, yer cars home now just got no idea where to start because it's had that 76 code for a while now.
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
I've got it on charge now so I'll do another code check in an hour or so.
its probably going to be the fact the battery is dead from not being charged i had this happen to me recently.
replaced the brushes in the alternator ($87 from repco) and she is as good as new. jumped the car. drove home the long way to give the battery a nice good charge and havent had a problem since.
been on charge now for couple of hours has plenty of charge and still no codes and no fire.
Could be your DFI , they tend to die suddenly, but should throw a few more codes. If you pull both leads off one of the coils and crank it is there spark ?
Are the S/C ones different to N/A's?
hmm dunno about the DFI's, I think they use the same DFI but i know they use different coils with more powerfull spark.
Try checking for spark as above, if you got no spark your DFI or CAS are prime suspects, supposing they are getting power to them ?
Just changed the DFI and it started straight away, just got me stumped why it wouldn't bring up a code.
Thanks for the help guys, much appreciated.
