Hi again
I had a Post a few weeks ago about my vr transmission slipping. I changed the oil and filter, but nothing changed.
I just did a computer diagnosis thingy and i got a code, (31, 47, 67, 68)
67-TCC ON-OFF Solenoid Control
68-Transmission Component Slipping
So the computer has picked up the slipping, but what is the solenoid??? Can this relate to the slipping. I'm hoping it is the cause because when it's not slipping it is a really smooth transmission and buying a second hand one it may not be as smooth.
K cheers guys,
btw i did use the search feature but couldn't find much on this subjectr
I may have broken the law, but that doesn't make it wrong!
sounds like you need a new box,would be cheaper replacing it there cheap as these days.
cheers 'uwishn' thats what im looking into, but I am wondering what the solenoid does,
its to do with electronic fields, i think.search it in here should find its purpose
tcc solinoid is the lockup solinoid for the torque convertor when doing 80kmh ish and cruising wont make the box slip
Scroll down the bottom of this page that you are on now - there is a section called "Similar threads" - you'll find 5 exact matches there which should confirm what people are saying - your box is on it's last legs.
