just wondering if i can put a vy dash cluster in the vs without to much drama ?
thanx guys
nar not necessary would just look better then the standrd cluster are they a diffrent size or shape ?
what would be the best cluster to pt in with minimal hassle thanx
Key words being "much drama", and yes it will be alot of drama. The only ones that will fit easily are those of the same model.
ok kool thanx guys if i got a level 3 vr/vs dash cluster will it be as simple as plug it in and away i go or will i bee cutting wires and so on
by the way i got a standard cluster in the exec
i think you'd need the dash wiring for a level 3 sub-cluster for that.
no cutting wires or anything though.
see a thread called tripin OR trippin<<< with 2 p's, not sure which one, but its got all the infor on fitting L3 dash.
