Results 1 to 8 of 8
Thread: will a T5 bolt to an ecotech
    Custom VL commodore(sold regretfully) + VR project
    May 2010
    Newcastle
    Default will a T5 bolt to an ecotech
    hi i got a vr as most of you know and my engine is about to die
    can i use my VR gearbox, flywheel clutch and pressure plate on an ecotech motor or not
    cause i can get an ecotech engine cheaper than a S2 buick
    mmm loving my VR
    VS Berlina 3.8
    Dec 2008
    You can use all of that, but the flywheels are weighted differently. You need to get a T5 Ecotec flywheel, or you can pay like $400 for a billet flywheel that bolts to an auto flex plate, that would fix this problem.
    May 2010
    Newcastle
    i just payed 550 for a flywheel to be made for my buick only 3 months ago hmm well whats better ecotechs or buicks??
    cause mine only has 170000 on it and the top end is gone
    mmm loving my VR
    Vs wagon
    Mar 2010
    south yarra
    will people PLEASEEEEEEE stopp asking whats a better motor!
    they both have thier ups and downs!
    a T5 will bolt up you will just need a different belhousing.
    as for the fact of putting a ECOTEC (not ecotech) into a VR that will mean changing or ECU all the wires and more.
    if you want the simple route just go to a wreckers and buy a new buick motor and transplant that into it seeing as your is gone.
    and if your buick only has 170,000 on the clock either its had a crap life and not been serviced or you have flogged the hell out of it.
    Quote Originally Posted by TrikkBen View Post
    Didn't BT1's come with eject buttons
    Quote Originally Posted by wez84 View Post
    And a lowered ash tray
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Yes, but you will need to have the VR flywheel balanced to the ecotec auto flex plate.
    May 2010
    Newcastle
    im only the 3rd owner the guy that had it before me flogged it abd blew the auto and 4 yrs it was sitting in his backyard till i bought it
    its been running like crap since i got it registed
    mmm loving my VR
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    Quote Originally Posted by bandidoben View Post
    same bellhousing. same gearbox bolt pattern from vn to vy v6's
    1994 VR S2 Acclaim
    Jun 2009
    North coast NSW
    Quote Originally Posted by wamboin23 View Post
    Yes, they're the same - but, I am told that the gearbox offset is slightly different from the VN-VR T5's to the VS-VY T5's. How accurate this is - I'm not sure, but, it will bolt up - IF the info I've been told is accurate, then the gearbox will just be on a bit of a weird angle (might pose a problem with tunnel mounts though).
  1. Ecotech in VN
    By Deathproof in forum Electrical Wiring / Questions
    Last Post: 18-06-2009, 01:29 PM
  2. vr ecotech,again..
    By 202injected in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2008, 10:19 AM
  3. My New Ecotech VH
    By Secki in forum VB - VC - VH - VK
    Last Post: 18-02-2007, 08:06 PM
  4. new bolt on turbo for ecotech
    By chevy_big_block_bro in forum V6 Development And Modification
    Last Post: 07-09-2005, 11:02 PM
  5. VL with VS Ecotech
    By pro_gmh in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-09-2005, 11:20 PM
