Results 1 to 9 of 9
Thread: is the vs cruise diagram the same as a vr
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Default is the vs cruise diagram the same as a vr
    i have the vs diagram but just wondering if the vr one was the same
    my cruise in the berlina is playing up. sometimes it works and some times it doesn't. it all comes down to if the crs light is on it will work, but if the light is off it wont (sounds silly but read on) i can press the on off bit on the stalk and i hear the bcm click but no light and no operation. repeat several times and it does nothing, sometimes it works but i think its just a quintessence. so most of the time i give up. than i hit a bump and it come on, but other times it just come on, press set and away i go.
    bye looking at the diagram it powers up through f10 through the bcm than t's off and goes to the dash and cruise actuator.
    just wondering what's the go, any one had similar issues?
    already suspecting bcm issues, i have seen my headlights turn back on after i locked the car up and had 1 flat battery with the lights on ( they turned off when the door opened)
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Remove the indicator/cruise control stalk and inspect the small wiring loom that comes from it. The wires have a tendency to break over time.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Also look at your brake switch as this is the most common reason the cruise wont ingauge.
    If not set correctly the system thinks the brake pedal is being used and cruise will not set. If it's on the edge of being set correctly it will work off and on.
    and 3 Dangerous non ABS VN's
    moff_man's Avatar
    Nov 2008
    but cruse works perfect if the crs light comes on. if it not on nothing happens its like it not on at all but the bcm clicks
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by moff_man View Post
    Cruise will not engauge if the system thinks the brake is on. One way to test this is to run 2 extender wires from the brake switch connector that you can hold together to see if cruise will engauge. A second person would be helpfull with this function. The test shows if the brake switch is set correctly or not. For the system to drop out over bumps I'd point at the brake switch first then maybe look for broken wire or the BCM. Brake switch first in my book - every time.
    DONT TIE THEM TOGETHER THO! - this would be very dangerous and the cruise would only dissengauge by turning the system off at the on off button.
    If it still wont engauge after doing this the fault will be else where
    moff_man's Avatar
    Nov 2008
    the cruse does engage if the cruse is on. but what im trying to say is the on light to say the system is on will drop out etc. which i thought was the CRS light.
    Jun 2005
    Doesn't sound like brake switch. Even if the brake switch was faulty, the CRS light would still come on, just not the ON light next to it
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    vs cruise uses a half size relay just above the fuses ....vr doesnt if you hear the bcm clicking it would seem the stalk switch is working but that the bcm isnt latching the power(on terminal b7 of the bcm on a grey/green wire) that is not keeping the power on the stepper motor(and crs idiot light)
    This is the vr one
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by markovr View Post
    This is the vr one
    beautiful that's what im after, also that's also the diagram i have, so ill relabel it in my documents
    thanks guys
  1. diagram for cruise control
    By grum1971 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2009, 10:11 PM
  2. Need VX Cruise Control Wiring Diagram
    By dc-tfp in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-09-2009, 05:41 PM
  3. Cruise control diagram.
    By Arm 1 in forum Electrical Wiring / Questions
    Last Post: 24-02-2006, 04:39 AM
  4. VS cruise control wiring diagram
    By bf6379 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2006, 08:48 PM
Tags for this Thread
