Doest anyone know what this random wire is that i have in the engine bay looks like its sposed to be connected to something of use lol haha
the wire at the bottom is solid green , then half way up it turns to blue and white
As said above,it looks like the temp sender wire for the temp gauge.
Does your temp gauge currently work??? That plug is for the small brass coolant temp sender screwed into the manifold just under the thermostat housing. It is supposed to be solid green but someone has extended it.
so its under the thermostat housing ? ive changed the thermostat sensor thing so it should it be under there ???
Yep, right under the thermostat housing/top radiator hose. Its facing directly forward and will look like a 10mm brass hex with a small round tit on the end that the plug clips over.
No worries! Glad to be of some help![]()
