Results 1 to 18 of 18
Thread: VS commodore Fuel pump draining 0.74a
    Vs Equipe
    Oct 2006
    Default VS commodore Fuel pump draining 0.74a
    hey all seems odd to me any help would be appreciated
    Car off fuel pump fuse in 0.97a - 0.98a
    car off fuel pump fuse out 0.13a - 0.14a
    is this normal ?
    My car seems to get a flat battery after two days its a new battery 2 weeks old been a problem for a while now checked the multimeter and these were the only results i found that reduced the 0.97a draw when the car is turned off
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd say it ain't normal. Check what else is on that circuit....at a first guess I'd say the oil pressure warning switch although normally this just shorts and blows the fuse. Have you checked it in the dark of night - look for light!
    Vs Equipe
    Oct 2006
    wouldnt the oil pressure switch cause a error code i get code 12 which is all good , its the fuel pump fuse in the engine bay that i removed its the only thing it fuses i beleive
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    The BCM (Body Control Module) is also on the circuit.
    All electrical circuits in the car pass through this module, & if there is an issue with this module it will continue to draw power.
    if you are still having trouble with this circuit you will need to test this by using a second BCM. however you will need the key (remote head) that is programed to match the second BCM.
    if you still have the current draw it will not be the BCM but I think you will find that it will solve the problem.
    Unfortunately it can be an expensive fix, but if you can borrow the bcm from another VR/VS that would be better.
    i Hope that Helps.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you will never have 0.00 current draw ecu is allways sucking power so is other stuff. ide unplug the oil pressure switch and see if the extra drain goes awaythough .
    Vs Equipe
    Oct 2006
    Vs Equipe
    Oct 2006
    whats the light got to do at night with the pressure switch just have the bonnet open and someelse cranking the car and see if it lights up ?
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    there is a know issue that a few members on this forum have had. its to do with the bcm and the auto light feature. if you leave the headlight switch on and you open the door the lights go out (normal) but for some reason the lights come back on later on say 2am or something silly. my vr berlina (high bcm) has done this once and since than (and doing some googlein manly finding jc threads) i never leave the lights on.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    Vs Equipe
    Oct 2006
    nargh my headlights dont stay on they always turn off when the door is opened but they have never turned on by themselves yet .....
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    What I mean't by looking at night for light means looking to see if the glovebox light or the bootlight is staying on....you can't see them in daylight ! Also the oil pressure switch is directly in front of the oil filter facing forward - has an electrical connector to it. To isolate it simply pull the connector off and see if you still have drain.
    Vs Equipe
    Oct 2006
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I thought the fuel pump fuse went straight to the fuel pump??? The purple wire yeah.
    My thoughts is someone has mistakenly hooked somthing up to this thinking it just to be a standard Accesories wire. Eg: they did some testing to find a acc wire and just stumbled on this one and used it.
    Is there anything non standard hooked in that might be causing this?
    Reaper
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by VrWagz1 View Post
    Apparently the oil pressure switch powers the fuel pump once the engine oil pressure is up - it's a safety thing so that if the engine stops in a prang/rollover, oil pressure will drop and power to the pump is cut so you don't have fuel spraying everywhere and then....bang.
    Yousay: Is there anything non standard hooked in that might be causing this?......aftermarket immobilisers can drain power so that's a good point.
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by hako View Post
    why is it than when the oil light comes on the car dosent cut out? i drove my car around for a solid week with a faulty oil pressure sensor and i still had fuel pressure, i also disconnected the sensor and it still started, i haven't seen the diagram in a while but are they in series or parallel?
    and what i was meaning about the lights if the switch was left in the on pos even tho the lights turn off with the door the bcm for some reason will draw current and flatten the battery. its happened to my car, and since i turn the light switch to off before leaving the car,i haven't had a flat battery in a while. it usually happens over night not a quick run in to the shops.
  15. #15
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    the circuit
    but you need oil pressure if the fuel pump relay fails or computer takes feed off relay for the pump to keep working until you get home
    If fuel pump relay is not energised ,12v can be fed from oil pressure switch (if engine has oil pressure)through contacts 87a and 30 of fuel pump relay to the fuel pump.....if ecm puts 12v on coil of fuel pump relay then 12v from fuse 23 feeds through contacts 87 and 30 of relay to fuel pump
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  16. #16
    Vs Equipe
    Oct 2006
    i do have a aftermarket immobiliser that was installed by a coconut so maybe he has #$%^^&$# something =/
  17. #17
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by moff_man View Post
    I'm not sure exactly how it works, but I'd guess that no oil pressure + no engine revolutions means the ECU cuts power to the fuel pump. This is indicated by when you first start the car, the ECU primes the fuel pump for about 2 seconds, engine starts and oil pressure builds and the oil pressure switch then powers the fuel pump. If the engine doesn't start and the ignition is still on, the fuel pump does not pump. Otherwise, the fuel pump would be running whenever the ignition is on and the engine stopped. The wiring diagram does not explain what parameters the ECU needs to supply power to the FP relay.
    No oil pressure does not seem to cause the ECU to cut power, but no oil pressure plus no engine revs will cut the power.
  18. #18
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the oil pressure switch is a backup circuit should the relay fail or the ecu goes into limp home mode means the fuel pump will run when oil pressure comes up from cranking so you can get home.
  1. Vr commodore fuel pump issue? and suspension question
    By VR_Acclaim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2010, 10:30 PM
  2. Humming Fuel Pump - VT Commodore
    By Paully in forum General
    Last Post: 23-03-2010, 08:32 AM
  3. vr commodore, power draining after couple of days :S
    By Big_Jay_91 in forum Electrical Wiring / Questions
    Last Post: 25-10-2009, 09:15 PM
  4. HELP! Draining fuel
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2007, 02:16 PM
  5. Bosch High Pressure Fuel Pump Kit Brand New For VP Commodore
    By Cobez in forum Parts And Other Items For Sale
    Last Post: 26-09-2007, 06:23 PM
