Results 1 to 10 of 10
Thread: Transmission help!
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Question Transmission help!
    Hi guys.
    I no this has prob been covered a million times but ill ask anyways..
    I have an early 95 VS commodore with a stuffed gearbox. I also have a Late 94 VR thats been smashed but has a 5HDD gearbox in it. Is it possible for me to take the 5HDD from the vr and put in the VS? Will it just be a straight swap? Thanks guys!!
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Even tho the one out of the VR is a 5HDD? Its confusing everywhere u look has a different answer? The transmisson in the VS only get 1st and 3rd gear. Was really hoping that the one from the VR would fit.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The VS came out in April '95 with the 5HDD box - I'd check the electrical plugs to the transmission - if they are exactly the same with identical pins. My rapidly declining brain recalls reading on this forum many moons ago that late model VR's had the same box as the VS.....but, as usual, I am not 100% sure.....so I would not dismiss it - get under the car, pull the plugs and start counting pins.
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    VX II Calais LS1
    Jan 2010
    VR 12 pin VS 13 pin, check your VS if it is a early one it may stil use a 12 pin. IF they are both the same number of pins it will work
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    RazzaCaine is offline Long Gone Now
    Mar 2010
    i thought the vs came out with the 4l60e transmission?? or are we talking v8 trannys here?
    VX II Calais LS1
    Jan 2010
    VN-VY had the 4L60E V6 and V8 just different models of the same box!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    5HDD means the box was made in 1995 (5) 6HDD means the box was made in 1996 (6) Both are 4L60E boxes but the digit refers to the year made.
    The 4L60E box for the V8 has a different identification as it's a bit heavier inside and has the deep pan.
    VX II Calais LS1
    Jan 2010
    the V8 boxes have the prefix 5HBD 6HBD etc instead of the V6 5HDD 6HDD etc
  1. VT Transmission into VS
    By Mag00ly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2010, 01:30 PM
  2. radiator differences 2 transmission lines or 4 transmission lines...
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2010, 12:10 PM
  3. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  4. VN S1 transmission in VP SII?
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2008, 06:11 AM
  5. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
