Results 1 to 10 of 10
Thread: It's done it AGAIN
    vs series 2
    Jan 2010
    Burleigh heads qld
    Angry It's done it AGAIN
    This is the 2nd time this has happend to my vs in a matter of months, auto transmisson sliping, first fix was to remove the pan and in doing that, i found the filter to be sitting in the bottom of the pan and not in the valvebody where it should be, fix: new filter and pan gasket.
    now it has done it again,
    Yesterday i removed the pan and bingo, the filter had fallen out of the valve body, Fix: new filter and pan gasket, but this time i have used cable ties to secure the filter in place.
    Now i beleave that having lowerd springs and shocks to give it a more stiffer ride is to blame,
    What would be your opinion on that
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    i rode on choppers for ages, didnt have a problem, maybe the bit where the filter slides in is worn out for some reason?
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    vn_v6's Avatar
    Aug 2009
    victoria
    and zip ties baaad, im pretty sure they will just melt mate
    vs series 2
    Jan 2010
    Burleigh heads qld
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    normally they sit on the pan and cant fall out probably dropped out when you pulled it off which shouldnt really happen either .is the rubber seal on the filter round the right way its made to hold one way round the other way it will not
    vs series 2
    Jan 2010
    Burleigh heads qld
    it has the deeper pan fitted to the trans, and yes the seal is fitted correctly, last time it happend the boys and i made sure the filter was fitted up all snug, but for some weird ass reason it has fallen out again, not to worry its all sorted out now, untill the next time lol
    в∞ѕтεכ √&
    Jul 2008
    NZ
    does the deep pan have a different filter if its not sitting on the bottom it will fall out
    vs series 2
    Jan 2010
    Burleigh heads qld
    yea they do have a different filter but the filter dosnt quite sit on the bottom and is enuff for the valve body to suck air causing the trans to slip and have no drive
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the hole the filter slides into - it's possible one or more of the sealing "O" rings from previous filter changes are stuck up there and preventing the filter neck seating properly. First one I changed was actually stuck to the tube hole as though it had melted on.
    vs commodore
    Oct 2009
    Tamworth NSW
    I agree with hako,Id check the hole where the filter seal goes in.There might be an old seal still in there.Ive serviced a few of these transmissions,and the filter seal can be a prick to remove.I just collapse the metal part of the seal inwards with a screwdriver to remove it.This might also explain why the trans has been slipping and sucking air.Ive never seen the filter sit right on the bottom of the pan,it sits close to the bottom,but not on it.If it did,this would stop or at least hinder the trans fluid flow into the filter as the filter inlet is on the underside of the filter.
