Results 1 to 11 of 11
Thread: Cam Shaft pulley bolt
    vr evecutive
    Jul 2009
    Question Cam Shaft pulley bolt
    I was wondering if anyone's got some ideas on putting the bolt back on tight,as i don't have a ratlle gun any diagrams or pics will be apprecated. Thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Do you mean "crankshaft bolt"?
    vr evecutive
    Jul 2009
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    If you want to do it the dodgy way just get an extension bar and a socket. Rest against the chassis rail and kick it over a few times just quick don't start it. Just make sure you get it the right side. I will not be held accountable if you smash something or hurt yourself.
    vr evecutive
    Jul 2009
    Thanks for that, how can i put the bolt on tight? is there any trick i can use since i don't have a rattle gun?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Just use the longest extension bar you've got. I'd also add some locktite to help it stay on.
    vr evecutive
    Jul 2009
    thanks guys for that now the bolt is on,but another issue has come up, when reved up to 3000 it starts to cough/puff abit,is it because it might still need to be tighten some more ,anything under 3000 rpm she's ok.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Why do you do it in the first place? Was it to replace the crank angle sensor? Did you replace it with a new or second hand one?
    vr evecutive
    Jul 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    What was happening that made you replace the CAS?
    vr evecutive
    Jul 2009
    wouldn't crank over and test code read.
  1. 2 questions- l67 10psi upgrade boost reading and the s/c pulley bolt.
    By wana s' charge stock vt in forum V6 Development And Modification
    Last Post: 20-05-2010, 11:10 AM
  2. Idler Pulley Bolt Loose
    By wicksey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2009, 04:05 PM
  3. pulley bolt part #
    By white vn ss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 05:27 PM
  4. Crankshaft Pulley Bolt
    By sulo2blue in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 12:26 PM
  5. Harmonic Balancer / Crank Shaft Pulley
    By knight97 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2005, 07:38 PM
