1) Where is the power steering pump located on a VS commodore ??
2) Does any1 have a step by step guide on how to remove it and put a new 1 in ??
Thanks for the help guys
there located towards the bottom of the block just follow the lines form the resovier and bam there it is..and its only three bolts to do
yer be careful wif the hi pressure line mate i am having trouble wif it
The high pressure line doesn't have to be difficult, use a crows foot spanner on it, the correct tools can make the job quite easy. if you can leave the bolts just in so that the pump stays put.
