Results 1 to 5 of 5
Thread: Heater fan not working
    SV8 VY Series II
    Jul 2010
    New Zealand
    Default Heater fan not working
    The heater fan/blower in my VS Berlina isn't working, you can adjust the heat etc, and hear the relay ticking when you adjust the fan speed, but the fan motor won't run. Have tried a different relay but same result. Have also checked fuses under drivers console.
    Any ideas? All I can think of is fan motor is blown or a wire has broken off, but hopefully this is a common fault and can be easily fixed!
    vs commodore
    Oct 2009
    Tamworth NSW
    SV8 VY Series II
    Jul 2010
    New Zealand
    VT SS
    Feb 2006
    use a test light to see if power is getting to the fan behind glove box, my blower fuse kept blowing which turned out to be the wiring loom that runs along side stereo has split and a wire was earthing out to stereo.
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Does your rear demister work and air con switch work?
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  1. VZ heater not working
    By Summer-Sickness in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-06-2010, 12:44 AM
  2. Heater not working in my VS
    By Gunzero in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2010, 01:34 PM
  3. vn heater not working
    By onlinejames in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 12:57 PM
  4. Heater fan is not working
    By vb_commie in forum VB - VC - VH - VK
    Last Post: 07-07-2008, 11:47 AM
  5. How to get heater working
    By hittmann81 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-04-2007, 12:37 PM
