Results 1 to 12 of 12
Thread: Best leads for Vr V6?
    VR V6 UTE
    Mar 2010
    Default Best leads for Vr V6?
    I need to replace the leads on my VR v6, it is a bit worked with a big cam, ported and polished heads etc, Im not sure what brand is the better and what size should I go for 8mm, 8.8mm?
    Any suggestions would be great
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Unless you are running forced induction or really stupid high compression, a lead is a lead. Doesn't matter what you use.
    Visit my Facebook page
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    As above, stock leads would be fine.
    I alway use genuine Holden. Not much dearer than aftermarket and come with new metal ends.
    VR V6 UTE
    Mar 2010
    Thanks for that, was thinking of going for a set of TopGun 8mm leads with the heat sheilds, around $85 from local Autopro.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    VS-II Esteem
    Apr 2010
    Tasmania
    I've always used Bosch performance leads and have found them to be reliable. Also, I think there may be a little to gain by using performance plugs such as Bosch super 4's. Maybe those iridium type might be okay. I know they're much longer lasting than standard ones.
    Blown 5l VS Calais
    Jan 2009
    SE Melb
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Don't bother with Magnecor either, they are supposed to be good for hi temperature, but i managed to melt the boots on track day.
    Genuine are good leads mate, and the heat sheilds actually fit properly so they last for ages.
    VR V6 UTE
    Mar 2010
    Cheers for that, I got some TopGun 8mm leads with new heat shields as well, the old ones didn't have heat shields on them at all,
    seems to have made a difference its idling a bit smoother, plugs where changed not long ago ( 1 month ) so left them in.
    Still need to look at the oxygen sensor yet.
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Commodore VS series 2 S pack
    Jan 2009
    Laurieton NSW
    i have top gun 10mm leads and they work a beauty around 120$ and they just give really good throttle response and somewhat better fuel economy
    VR V6 UTE
    Mar 2010
    Quote Originally Posted by Stokesy VS View Post
    I wasnt sure about the 10mm ones, thought they might have been to big, but the 8mm seem to be ok, my motor is worked a bit and perhaps should have gone bigger leads.
  1. Best Leads to use
    By VT2VEight in forum LSx Development and Modification
    Last Post: 13-10-2009, 07:30 PM
  2. Where to run RCA leads in a vx
    By Timy1990 in forum Car Audio
    Last Post: 05-09-2009, 12:36 PM
  3. top gun leads.
    By SUSS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2009, 11:46 PM
  4. top gun leads
    By joshsvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2007, 10:16 PM
  5. which leads to use?
    By rosco44 in forum V6 Development And Modification
    Last Post: 22-12-2005, 09:57 PM
