Results 1 to 5 of 5
Thread: x symbol in climate control window?
    vr caprice
    Dec 2009
    derro ville
    Default x symbol in climate control window?
    got an x symbol not flashing but popping up intermittently like a lose connection or something, just wondering what it might mean, no sign of a problem apart from heater tap doesnt move between 25-30
    any ideas?
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    Not sure if the VR setup is the same as the VZ but I had this happen recently. The X on the display means the outside temp sensor is faulty. I replaced mine ($25 sensor from Holden parts) and all fixed. Hope that helps.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    it means you have an error. i just had it happen to mine and all i did was unplug the sun load sensor and re plug it in. no issues since. there is a diagnostic you can do but i can not remember how to do it.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    VP Exec
    Jun 2005
    On a VP if you hold the off button down for 5 seconds within 10 seconds of ignition on you get the diagnostic mode. Push the hot button to step thru the diagnostics.
    20 is no faults
    21-27 are: ambient, in car , water temp, intake, sun, air mix door feedback, evaporator temp. sensor fault codes.
    hot again then demist to step thru function checks, 31-35, vent, floor etc.. - needs engine vacuum.
    hot again => temp sensor readings. Demist to step thru.
    fan button.
    Temp. should read zero. If not, adj. using up and down.
    Auto to finish.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Quote Originally Posted by Cheap6 View Post
    20 is no faults
    fan button.
    Auto to finish.
    Subscribing cause i'm sure i'll need this info one day.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  1. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  2. climate control,how does it work need to know for climate control conversion
    Last Post: 09-07-2010, 12:49 PM
  3. [VR-VS] How to change Heater Control globes (NON climate control)
    By Fonzie in forum Holden Commodore How-To's
    Last Post: 03-08-2009, 11:28 PM
  4. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
  5. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
