Results 1 to 5 of 5
Thread: Change or check fuses or rear lights
    VT Calais
    Jul 2010
    Default Change or check fuses or rear lights
    Hi Guys. New to the site so would appreciate any help. When I have the lights on there are no lights on the dash or any rear tail light or licence plate light. There is a warning light on the dash that is like a light bulb. When I looked up the manual it says that the warning is a rear tail light failure which makes sense but why would the lights on the dash not work. I really can't drive the car at night at the moment because I can't see the speedo. I first thought it might be a fuse but the manual says it is a rear light failure. Should I check the fuses first? If so how do I do this? I have searched the forum and someone said it was under the panel on the steering whell but how do I get the panel down with out destroying the panel? And how do I change the fuse? Where do I get the fuses from? etc I'm sorry about all the questions. If I need to change the rear lights or tail lights how do I do this? Were do I get the light bulbs from? Any help would be greatly appreciated.
    vs commodore
    Oct 2009
    Tamworth NSW
    Check the fuses behind the panel under the steering column.If you look at the panel there are 3 round clips that hold this panel in place,these clips have to be turned with a screwdriver before you can lower the panel.Just noticed your ride is VT.Is it a VT you are talking about?
    VT Calais
    Jul 2010
    Hi Brett_jjj. Thanks for the reply. VT calais 1997. Really appreciate the advise. Where do I get car fuses from? Also if it is not the fuses, how do I get the bulbs out from the back of the car. I presume I remove the carpet but how do I do this without damaging the carpet. Is it clipped in? And where do I get the bulbs? Thanks again.
    vs commodore
    Oct 2009
    Tamworth NSW
    Mate, you need to post this in the VT section.This is the VR/VS section,and I dont know exactly what the differences are with the VT fuses and tail light bulb replacement.I dont want to guess and then you end up stuffing something up.Heres a link to the VT section.---VT - VX Holden Commodore (1997 - 2002)--- Post your question again in there, and someone will be able to tell you exactly how you do these things.Cheers.
    VT Calais
    Jul 2010
    Thanks. Will do. Thanks again for your help.
  1. vn Calais rear lights, rear indicator, reverse lights and fuel gauge stop working
    By rustyguy085 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2009, 08:25 PM
  2. check engine lights etc HELP!!!
    By rubaduckee in forum Electrical Wiring / Questions
    Last Post: 18-02-2009, 04:08 PM
  3. VR Instrument lights out. all bulbs and fuses ok. Suggestions?
    By Tw11ga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2009, 07:13 PM
  4. how to check lower RH side fuses?
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-09-2006, 06:06 PM
  5. Check Thermostat and Coolant Change
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2006, 11:58 PM
