Results 1 to 3 of 3
Thread: Replacing electric antenna
    Jun 2005
    Default Replacing electric antenna
    Anyone know a good place to get a new antenna from? Heard of prices ranging from $30 to 200.
    Having problems with mine. I don't think its the 9494 antenna box thing above the ECU, because I took the antenna out of the car and put 12 volts to the red and white wires, as well as grounding the black, and nothing happened. Would that be a dead motor or mast?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    quite possible that the long plastic cog has snapped off in the motor jamming it, a new antenna is about $20 from repo from memory.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    The motor should have done something even if the drive cog is stuffed....try just red to 12v source and black to earth...you should get some noise. New mast and rope is 30 - 40 ish from supercrap ...but if the drive gear is worn you will be wasting your money..... the whole motor assembly is not cheap brand new and probably more trouble than they are worth...I put a switch in the glovebox on mine so it wasnt going up and down all the time and wearing itself out...secondhand is bit of a lucky dip.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. Electric Antenna installation on standard/non Electric ant VN/VP
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2011, 03:38 PM
  2. Electric Antenna
    By christopherVYpaul in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2010, 11:57 AM
  3. Electric Antenna
    By tomyy. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2009, 06:51 PM
  4. electric antenna
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2007, 12:52 AM
  5. Electric Antenna
    By Jono in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2004, 02:28 PM
