Today i was driving and my indicators just stopped working. Checked the fuses and they are all good including the hazzard but still no luck. Hazards dont work with new fuse, however the wind screen wipers are working. Any idea what the problems is? Would it be the indicator relay or maybe the stalk? Got me stumped
The hazard switch can some times take out the blinkers - just check the switch and it's plug. Have you worked on the car in the last few weeks under the dash?
and 3 Dangerous non ABS VN's
happened to me the other day.
just pull the hazard switch out with your hands and press it couple times and it works and just push it back in
hope it helps mate
check relay, although is the hazzards work it shouldnt be the relay..... next option is to replace the hazzard switch.... easily done just go to wreckers there are hundreds there.... all else fails try an auto elecie :P
opps wont do that again
