Results 1 to 6 of 6
Thread: K frame help plz
    VR HSV Berlina
    Sep 2009
    Default K frame help plz
    Hey all ... i have 2 vr irs commies 1 is v6 n 1 is v8 Can i unbolt the k frame out of the v8 n bolt the front n back frames into the v6 body? or could i swap everything from my v8 irs into the v6 irs frame does it fit? ... any help thank you in advance ... Cheers Bubbs
    VX II Calais LS1
    Jan 2010
    yes it will all fit, so long as you use the V8 engine with the V8 k-frame and V6 k-frame with v6 engine you can bolt it up to either one
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    VR HSV Berlina
    Sep 2009
    Thanx for that info bandit 10 didnt think the factory would have changed from one to the other , just wanted to be sure , so asked the experts , is there anything i would have trouble with , such as the loom or the body module(i know there will be some wiring issuses)but any major that anyone has run into , would appreciate any heads up you could offer , once again Cheers Bubbs
    VH factory v8 VR V6 acclaim
    Jul 2010
    New Zealand
    gotta luv the komy's aye vc to vs it is all interchangable, holden 6(202) and v8 is all the same was just the buick v6 and the nissan 6 that is different and the vr vs struts...
    v8 body control modules in the vr vs are the same part number as v6 not sure about wiring loom tho sorry
    VX II Calais LS1
    Jan 2010
    If there both VR's then the wiring will plug right in, only difference with the VS is the engine loom plugs in further up the drivers side near the screen instead of plugging in at the fuse box near battery like the VR does.
    VR HSV Berlina
    Sep 2009
    Hey thanx again fellas , have a sqizz on vr/vs thread (its under 93 supercharged v8 berlina) theres sum pics up will put more of the build up as they come Cheers Bubbs
  1. [VIC] WTB VN or VP V8 K frame
    By dans_vz in forum Swap / Wanted to Buy / Trade
    Last Post: 12-02-2010, 05:56 PM
  2. [VIC] WTB: VB-VS V8 K Frame for VP
    Last Post: 20-01-2010, 06:58 PM
  3. WTB in SA: VN-VS V8 K-Frame
    By 1991_Vn2nV in forum Swap / Wanted to Buy / Trade
    Last Post: 01-09-2008, 01:46 PM
  4. r&r vt k frame
    By CM99VT in forum General Discussion
    Last Post: 26-08-2008, 07:43 PM
  5. V6 or V8 K-Frame?
    By stuee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2008, 07:40 PM
