Results 1 to 13 of 13
Thread: Air bag light on all the time?
    johnsy_vs's Avatar
    johnsy_vs is offline =Johnsy=
    VS commodore series 2
    Jul 2010
    Laidley
    Cool Air bag light on all the time?
    the airbag light is on all the time and i dunno why lol... i was thinking just take the bulb out for road worthy? lol
    opps wont do that again
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Taking the bulb out won't get you through a RWC.
    The light comes on, then goes out to indicate the system is working correctly, including the bulb.
    Blown 5l VS Calais
    Jan 2009
    SE Melb
    Hey mate my airbag light is on all the time too, but it still passed a roadworthy. does it have an aftermarket steering wheel? or has it copped a knock on the front you're not aware of? Anyway give your Holden dealer a call they can fix it and its not overly expensive
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    A common cause of the airbag light is when the owner either partially fits a new stereo or has the dash partially removed and then turns the ignition on. Either Holden or an auto elec with the right tool can reset it for you. I've seen where people wire the airbag bulb up with the SRS light so it comes on and then goes out, but that really puts you at serious risk if you have a prang.
    johnsy_vs's Avatar
    Jul 2010
    Laidley
    oh ok thanks for the info guys and hendorockstar i know an auto elecie so ill get him to have a look and hopefully he has the right tool.. and srs light is clever too, but dangerous..
    menara200 is offline menara200
    VS Berlina S2
    Jun 2010
    JazzyJezza77 is offline Jezza
    vr berlina
    Feb 2009
    check the drivers steering wheel horn pad for lumps/or being uneven when u run your hand over it. good sign of a shaged airbag if it is replace it and i think you can clear the code by disconnecting battery for a while.
    VS Equipe II wagon
    Jul 2010
    Yeah, as menara said it might be the fuse. I used my air bags fuse to replace my blown brake lights fuse for a drive home one night and that light was on.
    johnsy_vs's Avatar
    Jul 2010
    Laidley
    aye havent checked that yet lol.... how stupid of me..... gotta start with the basics. thanks for the advice
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by JazzyJezza77 View Post
    No you can't, you need a tech 1 tool to clear the air bag code and turn the light off if that is the problem.
    Visit my Facebook page
    VT V8 Calais
    Mar 2007
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Any idea on the cost to do this, mine goes on when I accelerate and goes off when I brake?
    50LTRv8
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You may have a fault in the wiring if it does that.
  1. I changed the regulator, now the battery light is on ALL the time?? Help Please
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2010, 11:13 AM
  2. oil light on when idle and start. but no other time
    By D-Man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2009, 10:38 PM
  3. engine light on and stall time to time asap help
    By kevinwilly123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2009, 09:32 AM
  4. Replies: 2
    Last Post: 16-03-2008, 03:45 PM
  5. Check Engine Light when using new key for the first time
    By DzRBenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2008, 01:37 PM
