Results 1 to 7 of 7
Thread: VR Vacuum leak from Aircon controls
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    Default VR Vacuum leak from Aircon controls
    hey all
    just about at wits end.. XD
    I have a VR acclaim s2 and there is a hissing noise coming from the back of the aircon control unit(where vacuum hoses connect)
    It hisses with varying degrees of loudness depending on where the vent control is turned.
    It doesnt hiss on foot or the cool on top and warm on the bottom setting but it does on all the others..
    I have checked all the connections, replaced the entire set of vacuum hoses and tryed a different control unit..
    Anyone got any ideas? coz im all out..
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    The rubber seal behind the selector knob wears out and doesn't seal, pretty inexpensive part to buy new from holden, just a bit of time fiddling to change it over, if youve replaced the selector and the hoses then either the hoses are on the wrong ports or the hissing is coming from somewhere else.
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    I tried a different (non hissing) control unit and mine still hissed. I didnt remove the hoses only that rubbery thing that they all connect into and it only goes on one way
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    i dont know put some vasoline in the end of the hose connectors that connect the back of the selector to seal it more, it's either the hoses or the selector there's not much to it.
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    Good idea ill give that a try tomorrow even its only temporary shud at least identify the problem
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also check the heater vacuum switch which is near the selector.
    Attached Thumbnails Attached Thumbnails VR Vacuum leak from Aircon controls-heaterbutton..jpg   VR Vacuum leak from Aircon controls-hotvacswon.jpg
  1. vn heater controls? anybody else had the vacuum lines not work and are they hard to f
    By steveabbott in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2012, 12:39 PM
  2. snapped vacuum hose for heater controls....
    By roon_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2009, 03:51 PM
  3. VL aircon vacuum tube matchup. HELP!!!
    By dibly1980 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-07-2006, 09:40 PM
  4. VL aircon vacuum tube matchup. HELP!!!
    By dibly1980 in forum General
    Last Post: 23-07-2006, 04:13 PM
  5. Removing the Vacuum Block from the heater controls?
    By ProggerPete in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2006, 06:41 PM
