hey guys,
I've recently bought a vs acclaim series 2 and was thinking about ripping out the standard cluster and replacing it with drift iridium gauges, what i would like to know is how hard would this be and would it work?
cheers.
A bit of work but you can do anything that you put your mind to. Just plan it out. To keep it legal you must maintain all warning lights such as, indicator, engine, high beam etc. What you could do is get a cluster from a wrecker strip the insides (gauges) from that and wire it up into that. That way you know how much room you have and may even be able to use the factory plugs too. I have wanted to do this for a while but just upgraded to Level 3 cluster and am happy with that. If you go ahead with it let us know how you go.
what you will find hard is the speedo and fuel gauge with goin iridium series i dont think they realsesed them
