hy guy my centre bearingin my tail shat is roted,,i got a wagon here tha has a god tailshaft in it and i was wndering if there the same..also if tere not can u put 1 piece tailshaft int a irs commodore
Pretty sure that the Wagon shaft is longer, but you could just use the bits of the 2 shafts that will let you make 1 up the same size
If you are seperating the front and rear shafts, you MUST make sure the front and rear uni joints are 'phased' correctly to avoid vibrations.
Mark everthing before you pull it apart.
i think the ute and wagon tail shafts are the same length
ok cool can i get a one piece one use it at all?
