Hey guys, i swapped my VN for a VS about a month ago. The car is currently unregistered, and whenever i start her and put it into D it jolts into gear. OR if i put it in R then into D it jolts but not as much. Is the diff stuffed? Or loose screws? Or something else? The diff is LSD if that has anything to do with the problem? Any help is appreciated i dont want to waste my time putting it on the road and something happens to the back diff where it just sits while ive paid to have it on the road
With great cars, comes great drivers.
Sounds like it might be more the transmission. If you want to find out what play the diff has i'd jack the back end up on a nice level surface with the auto trans in neutral and with the hand brake off and start moving the back wheel hubs. If there's any slack in the diff you'll soon know. Just be careful when you have the back end off the ground and follow safety procedures!!!
Regards!
So if its the trans how much would i be looking at to have it fixed?
im having a similar issue as well, im guessing i just need to give my transmission as a good service. not sure if its even had a service at any point
better off buying a decent second hand one from wreckers with low k's, ive just got a manual conversion and have an auto in the shed if your interested? other than that get her serviced!! and also thake slayers advice with the diffGood luck!!
opps wont do that again
yeah im thinking of doing that or throwing in a manual. but what could the problem/s be? as from what ive described?
