Results 1 to 12 of 12
Thread: Strut Top Problems? I'm not sure if this is a bad thing?
    VS V8 Ute
    Jun 2008
    SA
    Exclamation Strut Top Problems? I'm not sure if this is a bad thing?
    Hey fellas
    Last week end (so the one before we just had) I put in some new front KYB struts and kept the existing strut tops as they still looked fine. Put them in now worries, but just checking things out today and it looks like the top rubber is like lifted off? Now I cant remember if this is the way its suppose to be or not? And I'm really sketching out and really dont want to drive it far!
    My question is, are they suppose to look like that? Or are they suppose to sit flat?
    First two pictures are of the passenger side one which looks like its up higher than the driver side (Third Pic)
    Thanks!
    Mark.
    Attached Thumbnails Attached Thumbnails Strut Top Problems? I'm  not sure if this is a bad thing?-sdc17138.jpg   Strut Top Problems? I'm  not sure if this is a bad thing?-sdc17139.jpg   Strut Top Problems? I'm  not sure if this is a bad thing?-sdc17140.jpg
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    VS V8 Ute
    Jun 2008
    SA
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by parbio View Post
    so just tighten the top nut you reckon?
    Yes, Well going by the pictures it seems it can be done up a bit more... I just done mine the other day and so far it seem to be ok....
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    50-60 Nm is the correct torque for the strut retaining nut while keeping the strut rod from turning. Looks like you have already over-tightened the support plate retaining nuts going by the damage to their faces, they only require 24-30 Nm. There is a note in my manual that you have to ensure that the upper strut bearing is oriented in the same way it was before you took it out.
    VS V8 Ute
    Jun 2008
    SA
    ohk so it's suppose to be 50-60 for the top nut? and 24-30 for the 6 other small ones? Ahhhhhh
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It looks fine, they do sit up a bit.
    Visit my Facebook page
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Well you must know then Mine do not seem to be like that though.
    VS V8 Ute
    Jun 2008
    SA
    James, if its not a massive problem for you, do you think you could take a picture of what yours look like, just to compare?
    Thanks, but if its too hard dw!
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Not_An_Abba_Fan knows his stuff, I was just saying mine does not look like how it is in your pictures..... But yes i can take a few pics
    VS V8 Ute
    Jun 2008
    SA
    Yer Not_An_Abba_Fan has helped me out before! Yer if you could that would be great!
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Just a couple of links from the "My Ride" bit showing how the rubber sits.
    My '97 VS
    my vs ute!!
    1997 VS SII S-Pack
  1. VT Strut Problems, Help!
    By casperinhere in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2010, 10:11 PM
  2. What Is This Thing
    By tyrefryer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2008, 11:25 AM
  3. Is there such a thing?
    By CANYONERO in forum The Pub
    Last Post: 09-03-2008, 05:53 PM
  4. Is there such thing as....
    By Iwannabeahsv in forum Car Audio
    Last Post: 10-02-2007, 08:52 AM
  5. One thing everyone should do....
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2006, 09:21 PM
