I've got a vr wagon and in getting a rear roof spoiler for it
How hard are they to fit, any tips or tricks would be appreciated
Do i need to get a template from some where to know where to drill
thanks
Do post some pics when you have it on.
Thanks.
Current ride: 94 VR Commodore Wagon, Series 1 engine in a Series 2 body.
Wheels: VE SS 19's custom machined to fit VR.
Sound: Kenwood + matching speakers.
thanks guys i will post some pics when i finally get the spoiler and fit it
its not for looks mainly just to keep some of the crap off that gets on the rear window in the wagon from driving
just the factory style rear wagon spoiler like on the pic below i found online
Technically not a spoiler - it's a dust deflector. I've fitted one to my wagon and it was a pain in the rear to do. I made a template of it so I knew where to drill. You have some leeway with the end but the two supports in the middle of the deflector, however, you will need to be spot on with your drilling.
Thanks Seraphic
your right i should have said a dust deflector instead of spoiler
sounds like it might be a bit tricky
did you drill the 2 mount supports in the middle first or the end ones first
cheers
have you noticed much of a difference on the rear window once it was fitted
I drilled the middle mounts first. I had a friend help me with this. Just make sure it is where you want it before drilling - gaffer tape it to the tailagte so it doesn't move. I also suggest drilling a small pilot hole first. If it is in the right spot you can always drill larger.
From inside you will never notice it but it does create a tiny bit more shade for the rear cabin area. Externally you will notice it, but it is not so grandiose that it looks out of place. I don't regret putting it on.
