+ Reply to Thread
Results 1 to 5 of 5
Thread: Climate Control Conversion
    '95 VS Calais, '75 Lancia Beta Coupe
    Dec 2009
    Burpengary, QLD
    Default Climate Control Conversion
    Hi guys,
    I was wondering if anyone has upgraded to climate control... Basically I wanna know what parts are different between stocko a/c and climate control.
    Looking at buying a wrecked Calais and pulling all the climate stuff out for another car.
    Any help appreciated
    Vn
    Nov 2006
    Glen Iris, Vic
    yeah man done plenty of times before. just swap the complete hvac box ( big black box behind your dash), it will require you to remove you dash completely, two bolt in the engine bay, and a few in various places around it. then the solar sensor that located in the middle of the demister vent covers, the ambient air temp sensor located drivers side infront of the radiator. and the vacuum solidnoid block an a few small sensors around it. and you'll have to patch a few wires and re-gass your aircon. you can get a climate system out of either a vr or vs.
    Dec 2009
    Burpengary, QLD
    tivoom's Avatar
    tivoom is offline pimpin pizza wagon tivoom Executive
    VR S2 Wagon
    Jan 2009
    newcastle
    while you at it do a full body loom swap it will save you chopping looms it what i did with mine plus i got power windows level 3 cluster tds cruise ect its the best thing i did
    Vn
    Nov 2006
    Glen Iris, Vic
    yes that is another possible option, not to hard either, just make sure you get the loom, keyfob and matching bcm to suit that way everything will work!
    i myself used a vs bcm in a vn s2 with the original vn ecu and got security etc working as i had a manual i didn't want the extra expense of a vs manual ecu.
+ Reply to Thread
  1. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 05:22 PM
  2. climate control,how does it work need to know for climate control conversion
    Last Post: 09-07-2010, 11:49 AM
  3. Climate control conversion
    By finnbe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-02-2010, 11:32 AM
  4. VR Climate Control Conversion...
    By mattakaspeeedy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2006, 01:21 PM
  5. Climate Control conversion
    By djpunkasspete in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-08-2005, 09:07 AM
