Results 1 to 5 of 5
Thread: dirty fuel
    vs wagon
    Aug 2008
    Default dirty fuel
    hi all i hve a vr wagon v6 and i think i have some dirty fuel in the tank what is the best way to remove the fuel without taking the tank out. thanks
    SS VN, VR Berlina
    Feb 2010
    New Zealand
    take the tank out lol. you can get most of it by undoing that hose right next to the tank, you'll still have about 10 litres in there though
    LAP004's Avatar
    LAP004 is offline lifes-likethat
    Vp executive
    Sep 2009
    qld
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    but wont all the shitbe at the bottom? how will taking pump out help, unless u take tank off and shake it with the pump hole down
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The only way to do it properly is to remove the tank and then flush it back out the main fill connection - that way you do not disturb the fuel pump, fuel level indicator and fuel return hose (break this and the problems really start!). If you think it is water, E10 fuel will eventually remove this (ethanol mixes with the water), but if you think it is solids check the fuel filter as it will show what has been trapped. The strainer at the end of the fuel pickup tube in the tank should strain all dirt bigger than a grain of sand but you still end up with all that crap still in the tank.
  1. dirty M5
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2008, 09:53 PM
  2. dirty dirty rear end
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2008, 04:44 PM
  3. fuel tank dirty as, plz help
    By Milkman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-05-2006, 09:51 AM
