Results 1 to 7 of 7
Thread: replacing a ECU wiring loom... ???
    johnsy_vs's Avatar
    johnsy_vs is offline =Johnsy=
    VS commodore series 2
    Jul 2010
    Laidley
    Question replacing a ECU wiring loom... ???
    hi i just got a manual ecu wining loom as i have converted an auto to manual , when removing the auto loom do i need to take the dash out? ive been told i have.
    Thanks in advence
    opps wont do that again
    johnsy_vs's Avatar
    Jul 2010
    Laidley
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The dash loom can be taken out via the side air vent. The engine loom should come out without taking the dash out (Left hand side).
    But if your replacing the whole loom that comes from the engine bay and goes around to the ECU from the drives side - yep dash pad out for sure.
    There is 3 main looms, dash, main and engine. 2 you can get away with, the main loom - no.
    and 3 Dangerous non ABS VN's
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    I wouldnt think so the ecm loom exits via the large hole on the passenger side and plugs into the main loom via the 8 or 10 pin ecm plug...all the transmission wiring exits out the same hole in the firewall so you shouldnt have to touch the wiring running along the back of the dash....you may have to move a wire or 2 to get the spedo to work.
    ignore the purple and yellow coloured wiring..... it just a old post showing the wire that has to be run for a l3 dash
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    johnsy_vs's Avatar
    Jul 2010
    Laidley
    thanks for the help but if i were to take the dash out is it a big job? and how do i do it? lol thanks
    VS ute
    Nov 2009
    Took me 2 hours to get it out the first time no I can do it within 30 to 45 mins.
    Best off getting someone to help you so your not changing sides all the time.
    Nick
    johnsy_vs's Avatar
    Jul 2010
    Laidley
    cheers mate sounds easier than i expected
  1. Converting a VS Auto wiring loom to a manual wiring loom.
    By johnsy_vs in forum Electrical Wiring / Questions
    Last Post: 28-08-2010, 08:45 PM
  2. Can i wire a speed alert to my VR without replacing wiring loom?
    By VRcommondoor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2009, 11:51 PM
  3. replacing wireing loom
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-10-2008, 04:53 PM
