hay people, my 96 VS commodore (automatic trans) is not running well when it is cold and will stall at any time while driving, but there is no sign of anything that could be causing it to happen, any ideas would be helpful.
Maybe do a code check -
Checking error codes VR/VS (Revised)
It's possible the coolant temp sensor has failed and is telling the ECU the engine is warm/hot when it's actually cold - this will cause a weak mixture when the engine is cold but when it warm up it is OK.
