Results 1 to 12 of 12
Thread: Which OTR CAI + panel filter setup gives the best sound - VR V6
    93' Pov-Pac
    Jul 2010
    Default Which OTR CAI + panel filter setup gives the best sound - VR V6
    I've got a VR S1 V6 with extractors and a 2.5" exhaust, but still have the stock airbox with that tiny stock air intake pipe. I'm looking into getting an OTR Cold Air Intake and a High Flow Panel Filter. I hear these give a slight power boost and improved fuel economy, but most importantly, will make the car sound better.
    Main thing i'm looking for is improved exhaust note. Air Filter Wise, would i be better of with a K&N hi-flow or a Lukey hi-flow? CAI wise, i have no idea? I see most people use the same one that the SS commodores have, but i hear there's other options such as SS inductions?
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Good luck getting a better exhaust note out of a simple filter change mate. The cheap Drift brand panel filter works good for the price. Your better off just making the hole on the bottom of the airbox bigger. The OTR intakes suffer from heat soak bad.
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    Changing your intake will not change your exhaust note. Yes you may have an altered induction sound and yes you may find you get slightly better fuel economy, but your exhaust note won't change.
    93' Pov-Pac
    Jul 2010
    Quote Originally Posted by wraith View Post
    So you're saying i'm best off to remove the small intake tube, cut a bigger hole in the airbox, change filters and leave it at that?
    Quote Originally Posted by wikky View Post
    Cheers, i got a little confused before. I meant to ask if the induction sound would change due to having a CAI. Some people say there's a slight roar under acceleration.
    VS 5 Litre BT1
    Jul 2006
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Yep cut the bottom of the airbox bigger. So easy and work's better then a heat soaking OTR.
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    if u wanted serious exhaust note alteration and a major induction nise then get some turbo love other then that,,,the ss induction or the one from holden and a k&N panels sound alright
    93' Pov-Pac
    Jul 2010
    i've been hearing that K&N panel filters don't fare too well in the filtration department so im giving them a miss, and am looking at either a Lukey or Drift panel filter.
    I hear both arent bad at all, but is one significantly better than the other?
    VZ SSZ
    Mar 2008
    Here
    Quote Originally Posted by Bizmark View Post
    What dipsh1t told you that? K&N filters are some of the best on the market.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    I doubt there's any noticeable difference between a K&N and a Drift brand filter. I have run both and have noticed no difference besides the extra money in my wallet from the cheaper Drift filter. The only thing you miss out on is a cool little sticker with the Drift filter.
    hq-racing's Avatar
    hq-racing is offline HSVR-28
    93 VR CLUBSPORT WAGON DAILY. 73 HQ PREMIER PROJECT
    Sep 2008
    S.A
    i run a lukey air filter in mine, does the job fine tho standard HSV CAI and wasnet over the top expensive..
    VR CLUBSPORT WAGON
    yes a clubsport wagon....
    LIVE THE DREAM
    VS 111 304 ute
    May 2009
    sunshine coast
    hq-racing where did you get your lukey filter from and how much$$ cheers
  1. [SA] FS: VN-VS K&N Panel Filter
    By exec24 in forum Parts And Other Items For Sale
    Last Post: 25-12-2009, 11:42 PM
  2. pod or panel filter?
    By vonny in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2008, 07:22 PM
  3. K & N Panel Filter
    By pk2k78 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-07-2008, 10:23 AM
  4. pod vs panel filter
    By vessm in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-05-2008, 04:26 PM
  5. WTB: K&N Panel Filter
    By xlr8_87 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-11-2006, 10:11 PM
