Results 1 to 20 of 20
Thread: vz ss brake upgrage for vr v6
    vr series 2 v6
    Oct 2009
    nsw
    Default vz ss brake upgrage for vr v6
    got a pair of vz ss brake calipars front, rotors and hubs front, also the bottom arm, which is the same as the vr, all that is different is the shocks, all up they cost me $100, so thought it was worth it and cant believe it all just bolted on with no hastles what so ever, arms and hubs the lot
    all i need to upgrade is my master cylinder from a 15/16 to a 1 inch and that should do the job
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
    RazzaCaine is offline Long Gone Now
    Mar 2010
    nice bargain there, certainly beats doing a vt brake upgrade. whered you managed to score all that gear so cheap? or do you mean just the shocks cost $100?
    vr series 2 v6
    Oct 2009
    nsw
    na he gave me the shocks and hubs and brakes, all i used was hubs, brakes and the arm, gonna give him the shocks back 2 morro night, $100 for all that, he is a mate and owes a few favours i guess lol but yea lucky, are the vt brakes twin pistons? these brakes are HUGE, they only just fit in my 17inch rim, wont fit 16's, lets just hope i dont get a flat in the front wheel, will have to do the old swap around wit the back wheel lol as my spare is only a 15
    master cylinder is $50, gettin that 2 morro
    Mar 2010
    yeah i think the vts are twin piston but they fit under 16s so obviously the vzs are considerably bigger still. sounds like you got a great deal with them. how does the car pull up now?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    You may find the 15/16" master a better option than the 1" unit.
    The larger bore master will cause the pedal to be firmer (but travel less) so you will need to push harder to generate the same braking force.
    It's really only VS that require a master cylinder upgrade as they have a 7/8" bore master which causes a low pedal.
    Is your car ABS equipped?
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    vz master isnt bolt up
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    vr series 2 v6
    Oct 2009
    nsw
    the brakes are fatter as well as bigger, they are 35mm thick instead of 25 or 30mm like vt's
    ive bled them and re bled them but the brake is real spongy, so i will have to go the bigger one, but RX25SE, you say it wont be better? but it will stop it from being spongy and not firm?
    no abs on it either does not matter, the master cylinder i got was for a abs car and did not have enough holes in the cylinder which really sucks, because it was dirt cheap as well
    pics will be uploaded tonight
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    thought vz's were the same as vt brakes?
    Reaper
    Nov 2003
    northside brisbane
    Quote Originally Posted by VrWagz1 View Post
    my vz are .......28mm thick fronts
    vr series 2 v6
    Oct 2009
    nsw
    is your vz the ss 6.0 litre model?
    ok sorry it took so long, i grabbed some photos and i know a few are blurry but u can just make out what it says on the tape measure, its bout 32mm for the thickness and 320mm for the diameter but as i said its hard to see, and it says on the rotor min thickness 30mm
    and pics are big sorry
    VrWagz1's Avatar
    May 2008
    wollongong
    How is that brake line for legnth on full lock? Jst looks short in the pic. Calipers look the same as usual vt/x/y/z stuff. But as far as the rotors, im not sure on what options/sizes came on what models.
    Reaper
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Looks like 2005-6 SSZ rotors. They are 320mm x 32mm.
    Part# DBA2020
    I wonder if the caliper piston diameter is the same as std. VT-Z??
    BTW. Maybe remove the hacked off bit of old hose!
    vr series 2 v6
    Oct 2009
    nsw
    found this on a forum, dunno how much truth to it there is
    WAY88T
    18-10-2009, 09:21 PM
    just a quick question about the brakes on the vz ss 6ltr .. is it just the front caliper that they changed or the rotor as well .. and the rears are standard still ?.. ( sizes of the rotors would help .. have tried to look it up but can not find anything)
    any help would be great
    Sideshow.
    19-10-2009, 05:16 PM
    The SSZ has 320mm front rotors and 290mm rear rotors, and yeah the front caliper is larger than standard SS, still twin piston though. I'd assume the series 2 VZ (6L) would have the same size brakes. The SSZ also has vented rear rotors, i'm pretty sure the earlier ones were solid.
    so i would say they are ssz brakes, because i know they are off a ute, so the calipars are larger than standard as well as the rotors
    vz ute ss or ssz? [Archive] - Australian LS1 and Holden Forums
    edit, just read what you wrote above, so they are ssz brakes, and to answer your question the calipars are different but still only 2 piston. that doesnt really answer your quetion
    and yea i know, gotta buy a new anglegrinder as all the teeth in mine have sheered to nothing :S unless it unbolts from behind which i doubt, but will get onto it
    edit also found this on that same page
    "As of 2006 and the 6.0 models, they kept these big brakes, but removed the red coating, reverting to "stock" finish."
  15. #15
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Interesting.
    If the pistons are larger than std ones then this would explain the low spongey pedal.
    That old bit of hose can be removed by undoing the clip.
  16. #16
    VP Exec
    Jun 2005
    It's difficult to tell from the pictures but is it correct to surmise that the pads have been swapped inside to outside in the caliper? If so, it should be possible to measure the piston dia. from the imprint on the pad with out even removing the wheel. VT- std is 2 X 42mm.
  17. #17
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Looks to me like you have the 330mm PBR upgrade kit, as the VT-VZ stock brakes were all the same.
    Visit my Facebook page
  18. #18
    vr series 2 v6
    Oct 2009
    nsw
    so thats a good thing??
    what size master cyldiner should i go? its got 15/16 in it, 1 inch ? getting a vn 5 litre (original not converted), would that have it in it? if not what size master cylinder do they use? and will i need to upgrade my booster?
  19. #19
    VrWagz1's Avatar
    May 2008
    wollongong
    Lots will disagree and some who have done the upgrade will agree that goin the whole hog and doing the vt/x/y/z booster/master upgrade is the only way to go with these bigger brakes. Compared to the stock vn,p,r,s brakes these things are huge and nothing that came standard on the 1990's commodores(bar vt) really has the capability of running these calipers effectivly.
    Reaper
  20. #20
    vr series 2 v6
    Oct 2009
    nsw
    yup so its a booster upgrade as well then
  1. Adjusting Hand Brake shoes ( disc brake )
    By Fusion in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-06-2010, 01:35 PM
  2. vr brake adaptor sleeve for vt brake upgarde
    By picks in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2009, 12:57 AM
  3. Some door handles & park brake & brake pads.
    By jabsy1 in forum Parts And Other Items For Sale
    Last Post: 07-08-2008, 09:53 PM
  4. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  5. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
