Results 1 to 12 of 12
Thread: VR temperature guage
    SS VN, VR Berlina
    Feb 2010
    New Zealand
    Default VR temperature guage
    i've been searching the forum but can't find any info on where the temperature guage should be.
    I recently bought a VR, it has the digital dash and the temperature guage just goes above the C mark.
    Can anyone tell me where exactly it's supposed to be normally? Or is this normal? Or do i have thermostat problems, anything.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Setting L3 V6 Temp Gauge to V8
    ^^ This link has the settings in volts. should help you a little.
    and 3 Dangerous non ABS VN's
    SS VN, VR Berlina
    Feb 2010
    New Zealand
    kind of, i was really just after what line it's supposed to be, thanks though
    Raremetal's Avatar
    Raremetal is offline Best of both worlds.
    Series 2 94 VR Wagon
    Jul 2010
    NSW
    Quote Originally Posted by VNCommyBeast View Post
    Well, from "C" mine sits between the 2nd and 3rd notch or what ever you call them. Hope it helped. (94 VR)
    Current ride: 94 VR Commodore Wagon, Series 1 engine in a Series 2 body.
    Wheels: VE SS 19's custom machined to fit VR.
    Sound: Kenwood + matching speakers.
    SS VN, VR Berlina
    Feb 2010
    New Zealand
    thanks, that is a lot of help, thought something was odd, wonder if it is running too cold or if my guage is broken
    88GreenVN's Avatar
    Jun 2006
    The gauge sender can be faulty and only cost a few $$ - may be worth changing that first.
    SS VN, VR Berlina
    Feb 2010
    New Zealand
    88GreenVN's Avatar
    Jun 2006
    On the VN's I have it's at the back of the manifold with a single wire to it. VR - not sure.
    It sits at the top of the coolant level for the car so have a hunt around.
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    Behind the alternator, one with the slide on connector the one beside that is ECT. Or you could have a faulty thermostat. For twenty bucks all up change sensor $10 from Holden and another $10 for thermo this should fix your problems.
    SS VN, VR Berlina
    Feb 2010
    New Zealand
    thanks fellas, i will get stuck in to that tomorrow, i'll try the sender first. The previous owner just put in a new thermo gasket a couple weeks ago, hopefully i can avoid undoing that lol. i'll let you know it goes
    jujibelly's Avatar
    Vr Commodore
    Apr 2009
    Melb
    SS VN, VR Berlina
    Feb 2010
    New Zealand
    oh is that all? effort putting it on, two whole bolts i have to undo lol
  1. VS Temperature
    By Acclaim96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2009, 09:09 PM
  2. VS Temperature
    Last Post: 24-04-2009, 02:51 PM
  3. I can't get it up (temperature guage I mean)
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2008, 07:44 PM
  4. VT Temperature
    By 05LVQ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-10-2007, 10:37 PM
  5. VX GTS Temperature
    By C4B in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2006, 05:06 PM
