Results 1 to 2 of 2
Thread: starting trouble
    vy calais .vs commodore
    Sep 2005
    blacktown
    Default starting trouble
    i have a vs v6 commodore i have been having a bit of trouble some times geting it to start some times when i turn the key it is like the battery is flat very slugish but u can turn it off after it does start and try it a gain with no trouble i have taken it down to get a new battery but they tested it and every think is fine it even the altanator is ok i have noticed the last coupple of days when you turn the key there is nothing but if you hold the key in the start position for a few seconds it will start any idears as to the problem thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try pressing th unlock button on the keyhead whilst the key is in the ignition just before you turn it to start ...this sometimes helps.
  1. trouble starting
    By crew.man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2008, 08:28 PM
  2. Trouble when starting
    By CMA in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-11-2008, 07:03 PM
  3. trouble starting vx ls1
    By FORCED in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2008, 08:27 PM
  4. Having trouble starting
    By will in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 11:24 AM
  5. trouble starting
    By 16 vk boy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-06-2006, 10:07 PM
