Results 1 to 3 of 3
Thread: Vr heater
    VR V6 5 SP WAGON
    Jul 2010
    Eagle Vale NSW
    Default Vr heater
    HI has anyone changed the heater core in a vr comm? IS there an easy way or do you have to take most of the dash out,and do you have to drain the air con gas ?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Lots of people will tell you that you must remove the dash which is 8 hrs labour minimum, but you do not if you follow the procedures suggested in this link:
    heater core on VS
    Good Luck.
    VR V6 5 SP WAGON
    Jul 2010
    Eagle Vale NSW
    HI Thanks heaps Hako,all the information i needed was at the link Thanks again
  1. vs heater
    By DvS_Ls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2010, 06:12 PM
  2. VX V8 Heater Tap, same as V6?
    By feistl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2010, 05:01 PM
  3. Where is heater tap
    By viper05 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-05-2008, 11:31 AM
  4. Heater tap - anyone know?
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2007, 02:05 PM
  5. A/C with heater ??
    By davey g-force in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-07-2006, 09:32 PM
