Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: Ideas On What My Hidden Switch Is For??
    RazzaCaine is offline Long Gone Now
    Mar 2010
    Default Ideas On What My Hidden Switch Is For??
    first of all, this is going to sound vague so bear with me. underneath the dashboard, under where you have the steering wheel theres the plastic cover that you open up which exposes the fuse box and wiring. inside this space there is what appears to be an aftermarket switch in my car, its a 2 way switch, like the one here:
    Google Image Result for http://ecx.images-amazon.com/images/I/41FkmYJauKL._SL500_AA300_.jpg
    my car has an aftermarket alarm fitted so at first guess i thought it was to disable the alarm, but it doesnt matter which position i place the switch into the alarm works the same regardless. then i figured that it could be an aftermarket killswitch to prevent the engine from starting, but again it doesnt seem to matter which position it is in because the car will start regardless. then i had another idea relating to the foglights. my vs has the foglight globes fitted in the main headlamp set up (not separate as in the ss for example) and when the previous owner had the alarm fitted they placed the l.e.d light which shows if its activated or not, in place of the fog light switch on the far right side of the dash. so i figured that maybe this switch under the dashboard was for the foglights but again no luck.
    im all out of ideas about what it could be for, anyone have any suggestions? id love to figure out what it is for and the only option i can think of at current is to try to trace the source of the wiring to the switch and see where it comes from.
    '87 VL Calais with L67
    Aug 2007
    that'd be the best bet. ive seen switches like that used to take brake lights out, interior lights out, rear license plate lights out, disable kickdown switches, turn footwell neons on (that may have been removed since) switch off sub amp power, line lockers, thermo fan alternate power etc etc.
    theres probably endless possibilities to what it can switch. i'd check with a test light to see whether theres power to it, and when (ign, acc, battery) and try and chase down the wiring after the switch to see where it goes.
    above all, good luck. you'll probably need it.
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    VS Calais
    Apr 2010
    Dandenong, VIC
    ive got one in my car and the wiring doesnt go anywhere, i just tell people its nos.
    Quote Originally Posted by minux View Post
    I think Camrys only stay afloat because Indians seem to be sponsored by them...well in Vic anyway.
    Raremetal's Avatar
    Raremetal is offline Best of both worlds.
    Series 2 94 VR Wagon
    Jul 2010
    NSW
    Quote Originally Posted by RazzaCaine View Post
    My father had one installed in his car, it was like a engine kill switch. Because he lives in Sydney he didn't trust his alarm. All it does is disable the connection to the battery there for rendering the car useless. But your cat starts regardless. Best bet it was something to do with them fog lights. Maybe hook something up to it? some in car LEDs?
    Current ride: 94 VR Commodore Wagon, Series 1 engine in a Series 2 body.
    Wheels: VE SS 19's custom machined to fit VR.
    Sound: Kenwood + matching speakers.
    VS III 5spd Ute
    Apr 2010
    Lake Macquarie
    It could be anything electrical that can be turned on and off in reality which makes it hard. Completely depends on what's/more to the point WHO's been playing with the electrics before you. I had a starwagon van once that died in surfers paradise (8hrs from home under my hotel,) long story short I needed to install and EFI pump due and blank off the carb. due to lack of tools, lack of proper information and a complete lack of time it ended up being hard wired into battery with a switch installed in the drivers footwell to turn it on and off every time i started/turned the van off. dangerous but it worked and got me home.
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    i have one which is not the same but similar,and mine is a panic button for the quick track security monitoring joint.
    My VL Walkinshaw replica project
    Mar 2010
    hmm tracing the wiring it is then, hopefully this will be easy but i doubt it...
    Patti2912's Avatar
    Patti2912 is offline P4TT1
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Let us know what it is if and when you figure this out.
    Purely for curiosity of course
    Mar 2010
    but of course =)
    i had a quick look at the wiring to the switch and discovered something. theres the wiring which goes to switch and attached to this wiring there is wiring which also goes into one of those white wiring clips (similar to this: http://media.digikey.com/photos/Avag.../HEDS-8903.JPG) which plug the wiring into the fuse box under the steering wheel. im now trying to figure out were this clip is supposed to slot in. the on slot in the fuse box isnt the correct shape for the clip with the switch so im not sure whether i should start unclipping things from the fuse box until i can find a slot that this clip will fit. im assuming that due to the white clip hanging loose and not being connected to anything it will mean the switch will not work. my line of thought is that if i can clip it into the fuse box i may be able to discover what the switch does without going to the grand effort of tracing the wire underneath the dash board. anyone got any suggestions whether its a good idea to unclip things from the fuse box so i can clip the switch in, or will disconnecting things from the fuse box break something?
    VS 5 Litre BT1
    Jul 2006
    Quote Originally Posted by Raremetal View Post
    ....Best bet it was something to do with them fog lights. Maybe hook something up to it? some in car LEDs?
    Or an ejector seat ????
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    i'd still be tracing the wiring, you don't know whether it needs to be a positive or a negative.
    also, how do you mean that the foglights are inside the main headlight assembly?
    VS Commodore Ute
    Nov 2009
    Mar 2010
    haha an ejector seat would be awesome!! with regards to the fog lights what i mean is that there are fog lights bulbs located in the main headlamp assembly with the low and high beam bulbs but the bulbs for the fog lights never switch on...
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    pics? thats something i would have never thought do-able.
  15. #15
    Mar 2010
    ok ill get pictures tomorrow, im pretty sure they are fog light bulbs. they are not low beam, full beam or high beam bulbs and im pretty sure theyre not parkers either. plus when i checked a catalogue (cant remember what company, was the main one sold at supercheapauto) the bulb number was for the fog lights.. the bulb im talking about is one like the following:
    Google Image Result for http://www.fordprobestore.co.uk/store/images/bulbh3.jpg
    and it is enclosed in the main housing...
  16. #16
    VT Commy
    Mar 2010
    Adelaide!
    Quote Originally Posted by VS 5.0 View Post
    Now that would be Bitchin!!? I can say that right?
  17. #17
    Mar 2010
    haha yeah you can, itd be great for when the misses is pissing me off, flip the switch and away she goes haha!
  18. #18
    VT Commy
    Mar 2010
    Adelaide!
  19. #19
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    Hmm I'd say trace the wire but that's so much effort
    I'd cut whatever running to it and hook up some LEDs
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
  20. #20
    Mar 2010
    yeah it is a lot of effort considering the wiring tucks right underneath the dash board and heads towards the engine bay. seeing how it doesnt do anything at the moment i may end up cutting the wires and hooking it up to something useful like some footwell neon lighting or something. hmmm, ideas ideas ideas...
  21. #21
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Lol, damn beat me to it.
    Could be something to do with a trailer breaking system ive seen something similar in a ford.
  22. #22
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    they are the high beam globes.
    towards the centre of the car, coming in from the top?
  23. #23
    Mar 2010
    ill have to check but im pretty sure they werent for the high beams. hmmm i could be wrong though
  24. #24
    VXII
    Nov 2009
    ...and hooking it up to something useful like some footwell neon lighting ...
    useful? pffft.
  25. #25
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    Hasnt anyone seen James Bond? Makes the machine guns come out the front grille, duh.
  1. what hidden features are in the mode switch
    By dzach23 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2010, 02:51 PM
  2. hidden switch on vh sle, now lights not working
    By YMY-88U in forum Electrical Wiring / Questions
    Last Post: 06-05-2009, 11:30 PM
  3. Oil Pressure Switch, ideas??
    By Brin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2009, 12:55 PM
  4. Hidden Tweaters
    By smyth in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-07-2006, 08:15 PM
  5. Kill switch ideas for VK?
    By electric_monk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-12-2005, 09:38 AM
