hi
car has been hard to start and cutting out,
I got a error code 49 or something,
cam or crank signal,
I beleive it may be the ignition module as it uses both sensors,
and its a hell of alot easier to replace than the crank angle,
So i will try the module and msd coils/ lmsd eads/ ngk plugs first.
Im just wondering does everyone use to replace when failed
genuine holden delphi or ac delco whichever it is
or non genuine?
or is there an aftermarket replacement?
also looking to keep sequential injection if possible(v6 ecotec in vs)
and planning a turbo setup in the near fiuture
thanks
If you are going Turbo you need genuine or better. There are aftermarket units $300 but they are pretty shitty in terms of short lifespan. best value could be a unto from wreckers, MSD if they make them, or genuine if you can afford it.
