Results 1 to 12 of 12
Thread: injectors for v6
    VN 5L 5SPD
    Apr 2009
    PENRITH NSW
    Default injectors for v6
    hi all i need some help. What is an injector a bit bigger than standard i have an adjustable fuel pressure regulator on the car now with the standard injectors running 44psi but it is just not right. The v6 has twin throttle boddies. Any help would be very apreciated.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    If I was you I would go back to using a standard FPR. There's nothing better unless your running stupid numbers. Which ever way you go you will need a tune to suit otherwise you will run into dramas. You could get V8 injectors. They slot straight in. If you car isn't turbo or supercharged I doubt you will have any issues with factory injectors though.
    HoldenManDan's Avatar
    HoldenManDan is offline Built, not bought...
    VS Exec SII 4.2L L67 T56 :D
    Jul 2006
    Penrith, NSW
    Mate you could try L67 injectors? If i knew the lb ratings i'd tell you, but i do know theyre a little higher than ecotec which are probably very similar (if not the same) as your buick. I think in one of the SC mags a while ago they put twin throttles on a vx ecotec and i dont think they played with the injectors, FPR or even the tune and it was fine. Who recommended you change injectors or FPR? Maybe you should try going back to the stock FPR and injectors and just change things as you need to.
    Hope this helps
    Factory 5 speed VSII, now 4.2 Litre L67 with T56 6 speed
    VN 5L 5SPD
    Apr 2009
    PENRITH NSW
    it is not really a problem down low its at high revs it leans out to much.
    VN 5L 5SPD
    Apr 2009
    PENRITH NSW
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Does it do it with the factory FPR? That would be the first thing I would check. When ever you do an injector swap you need to retune the ECU to adjust or it's going to flood the motor..as you have found out.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    supercharged injectors are 36lb twice as big as stock will just flood go get it tuned
    VN 5L 5SPD
    Apr 2009
    PENRITH NSW
    Quote Originally Posted by delcowizzid View Post
    i have asked you before about a chip would your chip be good enough or would i be better off putting it on a dyno and tune that way with a flash tune. thanks.
    When i put the supercharged injectors in i did it with the standard fpr. That was when i first put the motor together.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Why haven't you given up? I am sure I won't be the only one saying your wasting your time changing injectors and FPR on what is a relatively stock car.
    VN 5L 5SPD
    Apr 2009
    PENRITH NSW
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    get it tuned the tune controlls the injector pulses so if you put big ones on it floods think about it
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Go back to the stock FPR and injectors and see what happens. Also what do you mean it's not running right?
  1. AU Injectors in a VN
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-10-2011, 03:52 PM
  2. [VIC] 6 x 36lb Bosch injectors - VS-VY Super6 injectors
    By BLC in forum Parts And Other Items For Sale
    Last Post: 13-03-2010, 05:45 PM
  3. vu ss injectors?
    By loveless in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2009, 05:46 PM
  4. [NSW] V8 injectors
    By jason75 in forum Parts And Other Items For Sale
    Last Post: 28-03-2009, 07:16 AM
  5. Injectors
    By Deutscher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 04:24 PM
