hey guys i need some help ive just brought a vr statesman 5ltr im havning trouble with the gearbox, when i cruise the gearbox changes gears fine but when i put my foot down it takes ages to change from second to third, first to second is fine under high acceleration but it just reall holds out 2nd to 3rd any ideas?
all help much appreciated
cheers
doin skids for the kids and doughnuts for the grown ups
Is it revving out so much that it's red lining? Or just more revs than you'd like it to?
it will preety much hold it out as long as i want, but if i back off it will change into third
anyone??????
if it changes when you ease up on the accelerator it's probably just the computer telling it to hold the gear cos it knows you're a bastard that always wants to accelerate fast lol
thanks for the advice mate, could u possibly give me the basic run down on how to change it? its cool if u cbf lol
the solenoid is in the trans pan, so you will need a transmission service kit, (filter, gasket, 5ltrs dexIII) there are 2 solenoids at the rear of the box one is the 1-2 shift solenoid and the other is the 2-3 shift solenoid, they just un-clip and pull out hard to explain but you will see what u mean when you have the trans pan off, they are spring loaded so make sure you dont loose the spring when you pull it out
Here is a link to the solenoids on ebay, Shift Solenoid A+B 1-2+2-3 TH700 4L60E 94-ON DTC 81/82 - eBay Automatic Transmission, Transmission, Car Parts, Accessories, Cars, Bikes, Boats. (end time 21-Aug-10 21:10:15 AEST)
They wont set a fault code until they fail completely, so prob wont show up if you do a fault code check.
ok mate im guna get one and see how it goes. i wana service the gearbox anyway so i will update it once ive changed it, cheers for all the advice guys, much appreciated
if for some reason i cant replace both how will i be able to tell wich one is 2-3?
