Results 1 to 5 of 5
Thread: how to remove auto gear knob?
    vs maloo
    Mar 2010
    Default how to remove auto gear knob?
    Could someone tell me how to remove the gear knob on my auto. I tried to remove the selector cover but couldn't get it over the knob. There doesn't seem to be any screws holding the knob on. How do I get the knob off ?
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    not sure about the knobby bit - pretty sure its brute force tho---- but the selector panel will slip over it - just ---- need to turn it slightly and use a lil force - it;ll come off
    White Tiger's Avatar
    White Tiger is offline Semper Fidelis
    VN Executive Wagon VR Berlina V6
    Jul 2009
    Bordertown SA
    VS Clubsport
    Nov 2008
    Auckland
    As mentioned previously you shouldn't need to remove the auto gear knob to remove the cover, it just takes a little bit of mucking around to get the cover over. I usually unsecure the cover, turn it at right angles to where it normally sits and then slide it over the gear selector. If you do feel the need to remove the gear selector knob, you need to push it down and forward and it will "pop" off and it does take a wee bit of brute force.
    vs maloo
    Mar 2010
    Thanks for the info and links cheers.
  1. how to remove gear knob on vt auto
    By johnno010684 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2008, 03:19 PM
  2. remove manual gear knob from ve ss
    By kw1kaz in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-10-2008, 11:48 AM
  3. How to remove VT Manual gear knob???
    By gibbo1402 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-02-2007, 07:37 PM
  4. How to remove auto gear knob?
    By ascension24 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2007, 10:32 AM
  5. GettinG auto gear knob off?????????????!!!!!!!!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2006, 10:06 PM
