Results 1 to 10 of 10
Thread: VR O2 sensor
    V6 VR Acclaim
    Jun 2010
    Default VR O2 sensor
    Before anybody says 'Search', I'm just after a simple answer from anybody that is willing to help. While driving my 'new' 94 VR, the check engine light came on.. But only ever over 80 km/h. Anyway.. After paperclipping the ALDL connector out threw me error 13.
    Earthing problem with possible fix or just replace it? Where am I able to get genuine holden parts around Maitland/Newcastle area?
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    V6 VR Acclaim
    Jun 2010
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The earth problem is only applicable to the VS. Get a new sensor.
    Visit my Facebook page
    Raremetal's Avatar
    Raremetal is offline Best of both worlds.
    Series 2 94 VR Wagon
    Jul 2010
    NSW
    Quote Originally Posted by Not_An_Abba_Fan View Post
    How much are new O2 sensors?
    Current ride: 94 VR Commodore Wagon, Series 1 engine in a Series 2 body.
    Wheels: VE SS 19's custom machined to fit VR.
    Sound: Kenwood + matching speakers.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Mine is doing exactly the same and throwing 13 fault code....it means it is going open circuit or its going to a much higher resistance than what is considered within the normal limits...yep new sensor needed...only drama is how much you want to spend.....if ebay is your source I was planning on using a 4 wire vs one and joining up to the existing plug and wiring for around 50 bucks or go totally plug and play for 30 bucks more .....2 wire ones are a bit cheaper if your car uses that type...give away is how far away the sensor is from the engine if its near the cat it will be the 4 wire type as it needs a heater for it to operate properly......if its just clear of the exhaust manifold it will be 2 wire.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VR EXECUTIVE
    Apr 2010
    Tasmania
    just got my o2 sensor done when extractors where fitted, holden wanted $207 for one so went to repco and got one for $70 trade, it was 4 wire and needed to be wired up, cheers Bob
    VR V6 UTE
    Mar 2010
    After going to all the big name stores, and could only get a 4 wire universal one which then has to be wired up, I went to a small car parts place here in the Bay,
    and would you believe they had one that had the square 4 wire plug on it and for only $55 I believe it was a NGK brand as well.
    Anyway had it fitted up last week and that took care of my error code 13, now just gotta fix codes 21 and 22
    V6 VR Acclaim
    Jun 2010
    My local shop wants 80 for it. Not too bad I guess.. On an semi unrelated point, my radiator coolant is dirty and needs a good flush.. I have no money for concentrate, will premixed be okay for a week or so?
    1994 Vr berlina 3.8 v6
    Mar 2011
    Christchurch, NewZealand
    Quote Originally Posted by dk4400 View Post
    Hi people, i had the same issue as most of you, i have the VR V6. I got my self a universal o2 sensor, I put it in my self. Its a few months old now. But why would it be giving me the no signal code 13 ??
    I under stood the two white wires the sensor has, could go either way? And i put black with black, and grey with grey.
    Any Help??
    Pete
  1. what sensor?
    By HSV472 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2010, 11:47 AM
  2. VH heat sensor and petrol sensor!
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2009, 10:58 PM
  3. 2 bar map sensor
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2008, 05:25 PM
  4. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  5. VR V6 TPS Sensor
    By Stugutz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2005, 05:06 AM
