Results 1 to 12 of 12
Thread: VS cutting out while driving
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    Default VS cutting out while driving
    Hi, got a problem with 96 VS V6 auto. Wouldn't start last night, took like 15 seconds of cranking to get it going (usually starts first go, battery is brand new).
    Then today it just cut out completely with out warning (dash lights etc still on) while cruising 80kms/hr so I put it in nuetral and cranked it but wouldn't start.
    Pulled over and then it started perfectly?
    I'm gonna start looking at things like loose earths, and going to replace battery terminals anyway, but if anyone had a similar problem then do you know what could be a likely culprit?
    VS EXECUTIVE 3.8
    Aug 2010
    queensland, australia
    i had a similar problem and it just turnred out to be the battery terminals were loose so i lost power just for a split second
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    VS Acclaim Wagon, VE II SV6
    Sep 2009
    Canberra, ACT
    Crank Sensor. Exact same problem I had with mine. If it cuts out while driving just pour cold water over the front pulley and wait a few minutes
    Feb 2007
    WA Perth, Joondalup
    Ok it hasn't done it again so far, is the DFI the thing that is attached under the coilpacks?
    VS Commodore Series II manual wagon
    Jun 2010
    QLD bushland
    I have very similar prob with my manual VS .. engine warning lamp comes on and sometimes engine cuts out where I will need to clutch start it. Time to time I will not be able to start the car until waiting 45 min...battery terminals have been loose yet since fixng those tha prob still occurs. What are these codes people talk about and how would I use them please? This problem is driving my head inbloomy sane!! I stumbled across my fuel filter on backwards .. going fine now. However just today, on idle tha car temp rose to 3quart high started driving and normally temp will decrease, no not today it went off the rictor!!! I pulled over and it went down, fan kicks in and radiator is cool to handle. Is this the thermostat? given take Ive had probs with temp gauge previously just not this bad...
    greenacc's Avatar
    VE Berlina
    Jul 2008
    They are error codes mate . your computer logs codes when it detects a fault. Check the how to section for VS error codes.
    tim005's Avatar
    tim005 is offline Yet Another VS Ute Owner
    99' Series 3 VS S-Pac Ute.
    Feb 2009
    Melbourne.
    had this problem with my ute mate.
    was driving normally, running fine, then it just cut out and then started whilst driving.
    pulled over, checked plugs and leads and all the normal stuff.
    started fine, made it home.
    went to start it in the morning, cranked over roughly, idled for like 2 seconds then nothing.
    ended up being the crank angle sensor and something else i forget.
    http://forums.justcommodores.com.au/...first-car.html My VS Ute, 99', S Pac, 5 Speed.
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Jun 2010
    QLD bushland
    Thanks guys for all your help. Did fault codes lol (I think i expert on that now) 7 threw bak at me. cas was main prob..$90 later new sensor replaced thank gawd cos its running better - touch wood. Also anti-theft deterrent missing in bcmu which was creating a 45 min leeway before i could restart car- reset after sensor replaced just waitin to see if this prob still occurs...the car is in 'remission' for 2 weeks to see if probs are fixed. haha. Also o2 sensor missing as thats not as important i will do that after 2 weeks. Every1 told me it was cas so cheers. Also lotsa guys been talkin bout alternator wire that gets exposed and can cause fire..well mine is bloody bare as so warning to anybody else out there - Chek alternator wire!! I dont want no fire so if this preventable its getting done so a huge thanksu for all who made it known to me..
    Now imagine the facial expressions behind this 'car yard' !!
    VR V6
    Mar 2011
    sydney
    Quote Originally Posted by DoinItMyself View Post
    what do you mean about alternater wire being bare exactly do u mean where it bolts up to the back of alternator .......Cheers If you like u can email me a reply on mlrc-j@bigpond.net.au iam new to this i can never seem to find or no when someone has replied without going to a lot of trouble searching again......Thanks again
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Read this. It`s a sticky at the top of the page and welcome to JC.
    VS v6 owners check this out
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  1. vs 5.0 statesman cutting out while driving
    By Textavs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2010, 05:49 PM
  2. Keeps cutting out
    By peowpeow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2010, 09:37 PM
  3. Vs Commodore Cutting out while driving
    By brianthedigger in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2009, 10:16 PM
  4. VN cutting out while driving
    By electro cruiser in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-10-2008, 11:28 PM
  5. Amp keeps cutting out?? PLS HELP
    By Holdenboy_VS in forum Car Audio
    Last Post: 17-01-2007, 10:57 PM
