Results 1 to 11 of 11
Thread: Is it okay to run a thermo constantly
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default Is it okay to run a thermo constantly
    hey guys my thermo only kicks in some times ive tested it and it run perfectly off straight power. So i was wondering if it would be ok to run it directly off an acc power source so its constantly on,,of course ill fuse it and relay it but will it be fine for a quick fix until i get paid i have done it before on my vp and it ran fine for 2 years.. so will it be ok
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    your thermo will be fried alot sooner than its expected life if you do.
    what's the problem with the thermo at the moment, they kick in at a cirten temp 109 deg c and switch of at around 100 deg c and only runs below 40km/h and of corse when the a/c is on. there are many vr's getting around with misleading gauges and also blocked radiators, maybe a good cooling flush and possibly a new thermo stat.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    Vr acclaim
    Jun 2010
    flushed it today and it runnin a quater driving and the temp goes down very slowly while driving...i got a vs down stair that has a 3 weeks or so old thermostat are they the same?? its only gotten hot since i flushed it out 3 weeks ago done it again today with decent coolant and deminralised water and its still doing it.. any idea what it could be
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    You may have a blocked radiator of an incorrectly reading temp gague.
    If you have acess to a scan tool, you can read the engine temp from the coolant temp sensor rather than the gague sender.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You may have an air lock if it only started after the first flush.
    Visit my Facebook page
    Vr acclaim
    Jun 2010
    ive bleed and redropped everything today i cant think of what else it could be..
    jafo's Avatar
    jafo is offline lurker since 2003
    1999 wh statesman
    Yetisports 3 - Seal Bounce Champion!
    Oct 2003
    adelaide
    get a new radiator
    or run the fan i did it in my vs for 3 years never had a problem
    three thing in life are guaranteed
    taxes
    death
    and car repairs
    moff_man's Avatar
    Nov 2008
    if you have an air lock, running the thurmo fan constantly will not solve the issue it will heat up the area around the air lock and blow a head or crack it or such
    Vr acclaim
    Jun 2010
    radiator isnt that old how is the best way to get rid of an air lock i was thinking of taking tha radiator cap of and running the heater witht he bleeder cracked and seeing what will happen
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Here is my way of getting the air out of the system:
    With everything closed I fill the radiator through the cap.
    Also make sure the overflow if full to the top and lid is fitted.
    Blow through the overflow drain to pressurise the overflow and get air out of the overflow to radiator hose.
    The close the cap and run engine for 5 to 10 minutes watching the temp gauge. Sometimes I go for a short drive.
    Then with the engine still running, undo the bleed screw until a steady stream of coolant comes out.
    Then check overflow and top up.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Vr acclaim
    Jun 2010
    ohok thanks it not gettin as warm since my bottom radiator hose was not on properly but i will do this after work tommorrow
  1. VT V6 constantly missing under acceleration
    By BrentVR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2010, 05:23 PM
  2. ABS OFF light constantly on
    By Cashaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2010, 12:00 PM
  3. Vn V6 Constantly Stalls
    By mars in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2008, 03:02 PM
  4. Boot light constantly on
    By FadeToBlack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2007, 12:27 AM
  5. Lights constantly on
    By veclubby in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2005, 12:00 AM
