hi guys i have a couple of quick questions about this and i was hoping someone here might be able to help
my car is manual, is the clutch switch the same part number as the standard 2 pin brake light switch?
and
the four pin cruise brake switch, witch 2 pins do i plug the clutch swich into? ie the back 2 or the front 2
any help would be great
thanks
ben
for the second part the 2 away from you and the 2 nearest to you should got in to the loom hope this helps
heres my switch on my clutchthe brown wires are for cruise. The switch has 2 sets of contacts but the distance between male spade terminals of the contacts is different so you physically cant plug on to the wrong contacts unless you bend them pretty hard. Also you have to make a bracket for the switch to fit to.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
